Getting weird hitches every 20 seconds or so (stays @ 60 fps though...)
[email protected]
980ti...
Very annoying. Any one else getting this?
Does this game use physx and is it worthwhile if so? The latest build (Version:9.15.0428) doesn't list Windows 10 as compatible and I've seen issues with installing reported?
Couldnt hold out any longer got it for £20 done 2 missions so far and I'm loving it
Controllers are always better for third person games anyway.
Yeah just use a controller.
Game is so good.
Well, I'm getting some weird performance problem with this game, I have it maxed and I have a solid 60, yet most of the time it's looking rather unsmooth, if I stop in one area and pan, after about 5-10 seconds it becomes smooth. If I move a ways off or an area loads in like Mother Base it's not smooth again till after that amount of time. So as your moving a lot it's hardly ever smooth.
This is not something I had in Ground Zeros.
You tried using latest drivers? Cleaned with the DDU program?
Seen this game running perfect on two systems with 970 and 980Ti no issues/slow down whatsoever, probably the BEST PC/console crossover game I've ever seen.
Actually curious what the lowest card you could use to max this is? Seems so well optimized.
