Oh yesss, most likely a 2012 depending on what mileage and condition is like when I come to view!![]()
Good choice!
My Street Triple is a 2012, the best year they did
I was riding behind a R35 in grey gun metal today, that thing is a beast. So much torque, although is it normal that it was leaving massive piles of black smoke behind?
You sure about all that?
"Rear plug: Remove*seat, unbolt front of gas tank, tip tank upwards (make sure not to have it full of gas or it will leak out the top) and use a rod (one comes in the tool kit) to hold it up. The rear cylinder is right at the base of the tank. Pull the wire + plug out of the top of it, remove the spark plug with a spark plug socket on an extension. I believe there is a spark plug tool in the toolkit as well.
Front spark plug: Remove any necessary bodywork if a S model, unbolt the 3 bolts holding the radiator in place. Push radiator forward, there is the top of the front cylinder. Remove the plug and wire and then remove the spark plug with a spark plug socket. The factory tool does a good job of getting in there, as it is a tight space with the radiator there.
To install new plugs: put a dab of anti-seize on the threads, turn plug in by hand, once it is tight by hand, tighten with a wrench another 1/4 to 1/2 turn. Make sure it is snug but not overly tight, as you can strip the threads.
When putting the plug back on the front spark plug, put some dielectric grease in the plug boot, will help protect against water"
gonna have a big self portrait on you back like steve-o??
So apart from the total removal of the tank its pretty similar. The guide I read must be going a bit further so you have more space to work with.
I've posted in the SV forums to get some info on the fairing bolts as I dont want to buy a whole set of 2nd hand ones, just a few new ones
Today I hit a kerb with my back wheel as I lost traction on sand during breaking... I saved it, but nearly ***** myself...
Any recommendations on headphones? They can be bluetooth but can't be big as my helmet ear space is very limited... 1 thing for sure, they need to stay in my ears. My current in-earphones come out as soon as I put my helmet on...
BTW is Muc-Off chainwax better than WD40? The guy over at halfords said that their muc-off stuff gets sold more often...
