Took the standard head unit out in preparation for the new one arriving tomorrow..
Alarm kept going off every 5-10 minutes after that so I've just gone and put it back in.
Changed sidelight bulb in Wife's Fiesta, far more hassle than it should be - had to remove the whole headlamp unit as was struggling with it left on the car.
Beach Buggy Turbo's.
Wonder where all those missing chunks of metal have ended up.
I'd be taking off my head if i were you or going in with a boroscope.
It's the turbine so probably down the exhaust. Some of those edges look melted too so possibly high EGT's but you think thats not likely?
Also check the inside of the manifold for damage in case bits of the manifolds inner skin have broken off and that's what has damaged the blades.
Pull the battery/fuse?
It can be a bit of a pain to be honest, getting the head light out is the easiest part I found. Two screws, plastic rivet and brute force![]()
(If the fuse for the alarm is even easily accessible?!)
Although it was a white van that pushed me into the curb
