- 4 Aug 2014
Whats the performance difference between an OC 970 and an OC 980? It seems difficult to find data frustratingly!
No idea in percentages, although a well clocked 970 should get within reach of a stock 980 performance.
http://www.anandtech.com/bench/product/1351?vs=1355
Thanks, yes this is widely known though.
But the point is, if you are going to buy a graphics card, you are going to OC it.
So I have an 970, but there is a cheap second hand 980 I have my eye on, wondering what the performance increase will be.
Yes overclock! The KFA2 I linked will boost well over 1300MHz so it's not something you need to worry about anyhow.
The Gigabyte should be quiet yes, although any card you'll hear whilst under load.
I bought one with the reference (short) PCB. Do note that the cooling on these aren't as good however I can still clock mine to 1400 core without the fans going mental. It was cheaper, smaller and only needs 2x 6 pin however.
It's set to 1340-ish, which is what it ends up running at in benchmarks (Heaven and 3d mark I've tested it). Gaming it boosts up to 1400 no problem (inc ES:O BF4, War Thunder) even when at 100% load.
The problem is the power limit of 106% causes it to power throttle in low CPU usage scenarios, if I BIOS modded it to increase the power limit it wouldn't do this but I'd need 70% fan speed to keep it cool in any case.
It's this one here:
https://www.overclockers.co.uk/showproduct.php?prodid=GX-071-ZT
People say zoltac?
Isn't that an anti depressant?
I think you meant Zotac![]()
Is there much of a danger to OC a gpu..and may someone link me a guide. Want to check if its really worth the effort for the hardly noticeable performance difference lol
If you use Msi Afterburner and move the sliders up then yes it's easy, There is a danger of going too high on the overclock but normally you just get a driver crash and after a reboot Msi defaults back to stock speeds.
As with most things though you could be the unlucky one out of 10,000 to kill your card.
Grab one on offer, they all clock well so no need to go mental on price.
So the question i have as a prospective 970 buyer.
https://www.overclockers.co.uk/showproduct.php?prodid=GX-010-GX&tool=3&page=4
For the Coil Whine policy
or
https://www.overclockers.co.uk/showproduct.php?prodid=GX-009-GX&groupid=701&catid=1914&subcat=1010
For teh unlocked voltage, is it likely to make a significant difference?
