Funny, i bought the Kuro as it was cheaper but it works and it takes me seconds to wrap the perfect coil, however i recently ordered the Coilmaster Tab 521 and Won a Coilmaster V3 coiling kit with the order
Just waiting for it to arrive....
the chips default is set to use 3 cell, so if you build for dual 18650 and plug them in and hit fire, the screen will light up and go out as soon as you let get... so before it will run fully on the dual 18650, you need to plug it into a pc, run escribe, which will automatically check for and offer an update if there is one, then you need to change the power setting in escribe to tell the mod to use 2 cell... then its a good idea to run the watt-hour calculator to set it up to meter the battery properly.
Good Evening Everyone!
You may have noticed that some order have been set to completed.
If it has not, it will be updated tomorrow as we are processing them.
We are pleased to announce that the Cthulhu RTA V2 arrived safely today.
All orders are currently in the process of being fulfilled and will be shipping within the next 24 hours.
One thing to note - we do not recommend using the wick holder with the single coil deck as it can make things difficult to remove later.
Any hints or tips you find, please let us know as we are working with the new RTA at the same time as you!
If you have any questions, we've opened a public subreddit at reddit.com/r/vapourdepot to help create a FAQ guide for any products we stock. Help us help you!
Finally, you will receive an email from Trustpilot asking for a review. It would be appreciated if you could leave a review for us to help improve how we do things.
Anything you need, feel free to drop me an email and I'll answer as quick as I can.
Happy Vaping!
Once you've received the Cthulhu please let us know how you get on, currently torn between waiting on one of these or grabbing a billow v2!
Should I take the plunge on the IPV3 Li or not? Undecided, my most powerful mod is the IPV D2 at the moment, which is just about powering the TFV4 enough with the .2 coils, but the tank clearly needs about 20 watts more to get a better vape!
1 litre of PG arrived this morning, this'll last me absolutely ages as all my mixes are predominantly higher in VG, with the PG being made up between concentrates/nic.
Also some nice red heatshrink wrap to rewrap some 25R's, should be fun![]()
Will do, got my shipping invoice for it yesterday so with a bit of luck it might be there when I get home tonight, failing that tomorrow.
Do you need the 165w (or what ever it is) the Li kicks out? If not take a look at the IPV4S, 120w, 100J, titanium and nickel support, dual 18650 and is smaller then the Li too, iirc comes in around £38 on FT.
Maybe hold out for newer mods with either the DNA200 or the newer SX chip that will be out soon, hopefully in a smaller mod, the IPV3 is not that hand friendly unless you got big paws.
With the DNA you have unlimited support for wire thanks to the ability to add in the TCR from steam engine, including Hybrid wires used in Clapton coils etc...
Don't lipo ratings work out roughly at 3 x that of an 18650? So 1300mah on a lipo should be roughly 3900mah in 18650 terms.
Didn't know that about the Li getting a boost to 200w, shame it looks so awkward to hold.
