Worth deciding if it's worth the money for the gains or not, tuning N/A has awful bhp/£.
I know.
Just ideas. It would be more to smooth out the power curve than increase the power.
Thanks for the advice. It has the PPP kit so is running the PPP remap currently.
I'll look at getting one done relatively soon though - unless it's likely to cause any damage as it is? Starvation/overfuelling etc? (I'm not mechanically minded..) In which case I'll throw the stock airbox back in until it's ready for dyno/mapping.
It's a big no no on the 15's, upsets the fueling big style, I'd put it on when you get it mapped next
Suggestion from someone whose been mapping these things for the last 11 years...
Put the standard airbox back on.
It gains you absolutely nothing, even if remapped.
Steering wheel was nice, rest was meh and hate the pop up console screen
Went into limp mode. Looks like it's the coil packs which are under the manifold. £1800![]()
How did you find the glare on the pop up screen? Surely it must be a massive issue on sunny days (which admittedly are few and far between), even with my iDrive screen shrouded quite nicely if the sun is in the wrong position it can make it quite hard to read, so surely having nothing as a surround just makes this problem so much more frequent?
Went for a nice drive via Asda in Brighton, and afterwards noticed a dent in my drivers door. Scumbags.![]()
