Is the 750d airflow version going to be better in terms of airflow? Sounds like a silly question but I hear a lot that the solid front panel really restricts airflow.
Thanks
Thanks
Does anyone know of any places still stocking the airflow kit in the uk/Europe. I've just had an order with another reputable supplier cancelled as it had been sat in their warehouse queue too long.
It's your lucky day, we currently have it in our UK/EU webstore, http://www.corsair.com/en-gb/obsidian-series-750d-high-airflow-intake-kit
lol I'm surprised myself that we actually have it, because every time ppl ask me about it, its always oos.
Just received the intake kit, very nice, has taken a couple of degrees off my temps, so happy with that. Question, have other users removed the original dust filter that sits behind?
Random question but would a 280mm Alphacool monsta (80mm deep) radiator fit at the front of this case?
Without measuring you might loose the hd bay but can move the hds to the optical bays anyway
280mm fits in front tho.
I just bought a high airflow kit. I'll probably be using it to replace the dust filter behind. Is the kit effective enough at filtering dust by itself?
