Volkswagen cheats emissions tests!
29 Jul 2003
if the car cannot pass the MOT after the 'defeat device' removed then yes it'll be impossible to lower the emission unless i'm wrong
how does the 'defeat device' knows the car is about to tested?
is the 'defeat device' a software or hardware?
5 Apr 2009
What if they cannot pass? Perhaps it's impossible
Well if them passing is based on increased injection of urea as previously suggested, then one would imagine they'll just have to modify the cars to use more AdBlue so that they meet emissions in regular use, even if that means the customer will have to top it up 10 times more regularly or whatever.
Ultimately, I can see other manufacturers getting pinched for this, as everyone realises standards like LEV160 are just completely unachievable in the real world without copious amounts of additives that consumers won't want to be bothered with. I don't for a minute believe that only VW can't achieve this limit but all of the BMW, Merc, Ford, GM etc. diesel engines do it happily.
I also suspect little will happen in Europe if it is just NOx related, at least in terms of any cars that are aiming at Euro5. Euro6 may be a different matter but we're only really just encountering that now - it may be that we see a vastly increased use of AdBlue to what was expected too.
22 Nov 2006
The rest of the VW group are almost certainly doing it as well (Audi, Skoda, Seat), since they use the exact same engines. I wonder if the government will decide to pump up tax on diesel cars. Normally they will leap at any opportinity to get more tax out of people.
Maybe this is why emissions are always worse on equivalent Japanese cars. Maybe they aren't cheating (as much) :p
20 Apr 2007
The UK diesel emissions test is so half-hearted that it wont effect getting an MOT here, it's more how the cars fit into EU and other nation wide laws.
19 Oct 2002
Shakespeare’s County
What are you talking about.
This is about new cars and type approval for the various emission criteria. Nothing to do with an MOT. Euro 6 which is the big change for diesel and Nox across Europe. EU6c in 2018 will align EU Markets with US TIER III standards for new cars.
17 Oct 2012
Leeds
funny how they test them when they are new and then people go blank the erg valve, because it just gets clogged up and put a straight pipe on. i wonder how much NO my car puts out. :p
17 Mar 2007
Plymouth
Bring on the tesla model 3! I can't help but think we'll be wondering why we stayed with ICE cars for so long in 20-30 years when most cars are electric and the air quality in cities is vastly improved..
Don't get me wrong I have a 2.5l turbo diesel and like it but I'll go electric when it's affordable with decent range/performance.
21 Jul 2008
I certainly wouldn't, but then I've been of that opinion since 2012 when I had my last new VAG diesel for 3 months before returning it because of terrible fuel economy.
Caporegime
22 Oct 2002
Boston, Lincolnshire
Remember all those RS4s hitting lower power figures on rolling roads, I wonder......
Most likely because the engine was bench tested BHP. Lots of marques do this but N/A generally shows this more. Clio 182 comes to mind.
On a more serious note would this "11 billion" have a big effect on VW? Last thing we need is people losing their jobs!
29 Jun 2004
If you drove the universally accepted drive cycle on the road then you will get the same emissions output and fuel economy. Its basically like F1 rules, understand the rules then understand the loopholes for an advantage.
Same as here in UK, if you drive the NEDC route you WILL get the exact figures. however people complain that when they drive differently that their figures dont match.
Who's fault is this? The OEM who face big fines if their CO2 is too high so do everything they can to minimise NEDC emissions? Or the people who set the test cycle - which could be argued is unrealistic?
Lab testing in this context will be in a fully controlled chassis dyno.
I wouldn't bet on being able to replicate the actual economy figures as the manufacturers take some liberties when calculating the rolling resistance of the vehicles. Things like performing the coast down test at high altitude, using oil in the bearings instead of grease, active aero that shuts off the airflow through the vehicle all reduce the rolling resistance. Electric power steering means that no power is consumed when the car is sat on rollers, but it is rather difficult to drive with no steering input.
There is a lot more detail to all of this.
The brand new cars tested, especially diesel, have very different emissions profiles once the injectors start to get deposits. The fuel mix also has an effect on emissions which is beyond the control of OEMs.
What I don't understand is all the uproar about it, I bet most the people who are complaining about it also turn off 'stop-start' technology on their own cars.
I think the uproar comes from the fact that the cars actually exceed a legal limit that would have prevented the cars from being sold.
8 Mar 2006
Near Winchester
Are there any technical details on how it was achieved? The chap on TV this morning suggested they were just introducing more air into the mix, so the nitrogen oxides were effectively diluted.
More oxygen would increase combustion temperatures and increase NO (Nitrogen Monoxide) emissions. It's reduced by introducing inert gas (exhaust gas) to the combustion chamber to reduce combustion temperatures, or in VW's case by also adding urea from a tank to the exhaust.
It appears VW pump a lot more urea in if the car thinks it's in a test.
It's been widely reported as just software.
Yes, but if you fix it to pump enough urea into the exhaust all the time the tank will need filling more often than the service schedule. VW drivers will need to start peeing in their DEF tanks.
I'm pretty sure Peugoet run a small tank of the stuff filled at service too, they're likely playing the same game.
Maybe diesel owners are going to have to get used to adblue, like the truck drivers. Or VW can design their engines better, a lot of cars don't need the stuff currently. As to what the emissions are like when your EGR clogs up though...
I think it's in our best interests that the authorities don't start making the test more realistic, including sustained WOT for example.
20 Apr 2007
I was replying to people who talking about how this effects the car going through an MOT, hence my comment on the UK diesel emissions test. Keep up!
5 Apr 2009
[TW]Fox;28596707 said:
What difference does it make, NOX figures have no bearing on UK purchases currently.
Well, there are the usual 'experts' appearing on TV and radio saying things about how the fines could put VW into administration etc.
If people take comments like that seriously, they may well avoid the brand entirely in the short term.
