- 19 Feb 2007
Deleted - double post
Just had email confirmation that my AOC G2460PF has been shipped!
Way earlier than the 2nd October predicted ETA - nice on OCuK!![]()
Not mentioned, so I assume it has no strobing mode?
Nope - no strobing mode unfortunately.
. Seems like the only companies to do their own strobe have been
and out of those three, only benq have any strobing freesync
.- You can definitely tell it's a TN panel - the panel is overly bright and colours are very washed out. It isn't even as good as the AOC G2460PG I had briefly in this regard. Compared to an IPS panel it is very poor indeed![]()
All XL24 models, the ASUS VG248QE, AOC G2460PG and others use this same panel and they all show strange inter-unit variation beyond what you'd normally expect. The 27" models show some variation as well (even the ROG SWIFT does), but let's not go there for now.
I should be receiving this for review today or tomorrow, although won't get to try it out until tomorrow. I can advise on settings, but in the meantime I would recommend trying the different gamma modes as well, if you haven't already. I will also say this. I have noticed from all monitors I've dealt with which use that same AU Optronics M240HW01 panel that there is immense inter-unit variation in the panels themselves. Often these aren't corrected for properly by the manufacturers, leading to differences in gamma behaviour (and of course colour temperature, as expected). So it may even be worth swapping it for another, but I will advise once I get my own. If I'm honest, I wish they'd sort the panel out or in fact use a new one. That panel has been overused to high heaven on 24" 144Hz monitors now.All XL24 models, the ASUS VG248QE, AOC G2460PG and others use this same panel and they all show strange inter-unit variation beyond what you'd normally expect. The 27" models show some variation as well (even the ROG SWIFT does), but let's not go there for now.
Regarding the 144Hz behaviour with overdrive, I will inform AOC of this immediately. I noted exactly the same thing on the AOC G2460PQU I reviewed a while ago but that was supposedly rectified in newer revisions. Overdrive will be disabled at 144Hz if the setting is greyed out.
Thanks for the quick feedback Termintor, that's a bit disappointing. Although as somebody who has only ever had TN panels I guess it may not bother me as much as some. I thought it a bit odd as most people seem very happy with the G2460PG, but I guess down to luck based on what PCM2 is saying.
Also the more I look at pictures the more I'm put off by the physical styling, though not a massive issue. Think I'll wait to see what you think of yours PCM2, look forward to it.
Shame there is such a lack of 24" Freesync!
Thanks PCM - that information is massively appreciated.
It definitely feels that the overdrive is off - the image is very smooth but the response time is not 'tight' for a 1ms gtg screen - it's difficult to describe.
I have had logged a support ticket with AOC to see what they have to say about it as well - unless it is fixed then I don't understand where they would get their 1ms gtg figure from as I'm sure that requires overdrive to meet.
Regarding the colours, I improved these slightly by using the 'gamma 3' setting and dropping the constant to around 30 in the OSD but it's not exactly night and day.
I'm happy to try and correct the gamma in software, however, I'm pretty sure this isn't foolproof as doesn't games often tend to ignore this (or is that ICC profiles?) leaving the windows desktop fine but games still looking 'off'?
It's always best to try to improve things with the OSD rather than through the graphics driver, yes. I know a few tricks with AOC models to change their gamma behaviour beyond the 3 settings available, but I'll have to see if it's possible with this one first. I am eager to hear what they have to say about the 144Hz overdrive thing. It seems like they've taken a step backwards in that regard.![]()
I'm very eager to know as well and I'm very appreciative of your help with this as information on this monitor being so new is scarce at the moment.
I'll also post back here if I get a reply from my support request on the subject.
Also very interested to know your 'tricks' if you confirm it is possible with this monitor.
I've got the product manager on the case, so don't worry too much if the support guy doesn't really help you out.![]()
Was seriously thinking of buying this when I got home from work today but think I will hold fire now.
So with overdrive disabled does in feel like input lag?
I'm going to upgrading from a benq 24" TN panel which I think the specs says 1ms response time.
