- 11 Mar 2013
With 980Ti release just slightly after Titan X for nearly half the price imho hurt nvidia creditability a little. I for one wont fall for this trick again.
The 16FF+ Pascal dies will be a lot more expensive than the extra mature 28nm Maxwell ones. The wafers are almost twice the price.
I wouldn't expect NV to eat that cost. It'll probably blow way past the £1000 mark on release. Unless they leave it and stick with the 1080 until costs can be brought in line with what the market will bear. Then again, people will certainly pay £1200 or more for a Titan. But how many?
Will the 1070 be priced like the 970?
I cant quite understand what we are gonna realistically gain with these next level cards.
The games by the time of this release are going to be almost identical to what we have now with regards to requirements.
So lets say it will be able to play The Witcher 3 at 4k 100fps. Wow.. Playing a game that you have probably already completed 1.5 years previously, but this time after paying £1000 to get more FPS. How about Farcry 4 at 4k.. uh huh.. we been there.. Batman... GTA V...
I appreciate the advancement of technology, but I would be surprised if there is anything remotely mind blowing by the time the next gen comes out.
Fingers crossed developers really do push it to the max with games, but since the market for a £1k card is so small I doubt they will see a return on their invested time.
I genuinely hope I'm wrong, but AMD's new "we're premium too!" marlarky does not fill me with confidence for a new price war![]()
I agree with your post.The only reason to get the high end pascal is for 4k or if you want to play at 1440p and have 100+ fps with 4xaa on every game. The FPS at 1440p on a 980ti is already very good.
The jump from 1080p to 1440p is not the same thing as the jump from 1440p to 2160p, though. I think that's important to point out.
I'd say the 980Ti is the perfect 1440p/60fps card. But I think the leap to 2160p is underestimated by many. It is a huge, huge leap in terms of pixels needing to be rendered. I really think we need at least 60-70% more power than the 980Ti to have a 2160p/60fps capable card, given a small allowance for the fact that 2016 games will have continued raised demands.
4k is truly an incredible resolution leap that is an order of magnitude higher than we've ever dealt with before. Just a reminder - it is FOUR times the resolution of 1080p.
But up until now Nvidia's mid-high end cards (970/980) have always been a bit crap at higher resolutions because of the small memory bus, but if there are going to be HBM mid-high end cards, then that won't be a problem. So unless you want 4k 60fps or 1440p at 100+ fps on every game, then the 970/980 pascal equivalents should be better than they have been on GDDR5. So there might be the 980 pascal equivalent which is faster than a 980ti and lower TDP than a 980.
Do we know that all Pascal cards in the 10xx series will use HBM? Same with AMD?
Is there a chance they'll stick with GDDR5 for the lower-end offerings?
I make some allowance for the fact that you don't always need 2x the power to power 2x the resolution(it's dependent on various factors), and also that HBM2 will provide a performance enhancement/bottleneck remover at such high resolutions. AMD Fury line-up's HBM1 has already proven to show marked increased competitiveness at 4k over Nvidia's GDDR5 cards, and HBM2 will provide another doubling of bandwidth over that. That may not mean a doubling of performance increase over HBM1, but it certainly means that 4k wont require a raw quadrupling of power over 1080p.Its over twice the pixels of 1440p, so to run games at 4k a card over twice the speed of a 980ti would be ideal, to run every game at 60+ fps with 2xAA or even 60-144fps when 144hz 4k panels are released, a card 3-4x the speed of a 980ti! As you said if the pascal is 50% faster than 980ti then that is still not great for 4k.
We don't know anything, but I think it's possible that either GDDR5 or HBM1 is put onto the lower end cards. GDDR5 definitely on the commercial low end cards(<x50 cards).Do we know that all Pascal cards in the 10xx series will use HBM? Same with AMD?
Don't know but it would be a bit crap if they stick with GDDR5 and only have HBM on the £500+ cards.
