Maybe even the same wrongly quoted range for all we know...
It's been tested, works as advertised. Working overdrive mode as well.
So it's not like 30-144 freesync is impossible.
The nixeus has? Have you got a link?
http://www.pcper.com/reviews/Displays/Nixeus-Vue-24-1080P-144Hz-TN-30-144Hz-FreeSync-Monitor-Review
Nixeus doesn't have the greatest rep, but if such a tiny company can do it, I don't get why any of the major ones can't make this happen.
And the A model is only $280 now.
I haven't really tested FreeSync enough to confirm exactly what the lower range is. But my initial testing suggested it did go down to 30Hz as AOC confirmed (to me earlier and also here). I haven't actually tested this with VSync disabled yet as I despise tearing. I actually don't have a scientific method to test this either way, it's really just a case of comparing with and without. Framerate limiters are probably a good way, but I tend to find using the 'Resolution Scale' feature and adjusting MSAA on BF4 a good way to test frame rate ranges and fluctuations.
Thanks for this Henson, very useful and quite happy to see that it works on the majority of your titles. Arma3 is one of those ones that should work with the profile in Borderless but not normal Fullscreen. Then of course FreeSync is disabled! Also, did you use the 'DisplayProfile' utility to help easily re-activate the profile if Windows resets on game exit?
All,
I'm pleased to announce a world's first review (I think) of the AOC G2460PF for your viewing enjoyment:
Hope you enjoy it and find it useful!
- TerminatorUK
Not watched the YouTube video but looking at the written review they say it's bottom limit is 30Hz but I can't see where they actually test it and prove it works. Seems like they are just reading off a spec sheet like AOC have.
Same with the overdrive function, they have not made it clear if they have tested with 144hz and freesync on or at 60hz
Really enjoyable watch and full of really useful information on the monitor. I think you summarised it perfectly at the end really. A good entry into the world of FreeSync and you could do a lot worse for the money. But hopefully that overdrive issue can be resolved, as that would certainly make it easier to recommend.![]()
i am no reviewer of any kind however i am more than happy with it for the price.
The freesync range is a non issue for me, the only game with lower than 50fps is dcs world and the engine update is coming soon which should resolve lower fps.
the colors are spot on with the settings and profile provided by pcm.
the overdrive being greyed out is a slight issue, however i am hoping it can somehow be resolved. on that note can anybody with the monitor, test the monitor being plugged in via vga with 120 or 144hz selected for me please, is the overdrive function still greyed out? aoc are insisting i test it via vga, however the msi 390 doesn't have vga..
I'm not confident VGA even supports those refresh rates? Anyway, I'm not sure how it is going to play out or the logistics of it, but the issue is going to be addressed. They're sending me an updated model which should give full overdrive control >60Hz. I can't say more about what will happen retrospectively for users that already own the monitor, at this stage.
Well I'd like to hope a free RMA service to replace the faulty units would be in order!
Good news though - I hope an AOC will come here to post their plan soon. If nothing concrete manifests itself within the next week, I'm returning mine within the DSR period; I'm not going to run the risk of a 'maybe' fix.
