@Pokerking: that sounds about right, the Smok Cube shows live resistance, so when you put in a new coil and both the mod and tank are at room temp, your mod reads the tank and sets and shows the base resistance, in this case .28, then when you fire the mod, the Cube II will actually show you the resistance change, in this case up to .66... this is normal on the Cube II, other china chips have the same feature, unlike the DNA chips which only show the base or resting resistance.
Thats how temp control works, you see Ni200 and Titanium are such low resistance that as they heat up, the resistance changes enough to be read, the chip reads the resistance and uses an algorithm to work out the temp because they know the relationship between temp and resistance on these wires.
@Twirlywoos: Stealthevape does do Grade 1 Titanium, that's where i got my 24awg TI from. Also got 26awg from The Crazy wire Company.
When using TI, it is recommended to clean the wire with Alchohol before using, but to be honest, i just wipe mine with a tissue, as long as there is no residue left then i build.
A fresh coil can taste a bit "odd" for the first dozen puffs, but after that its sweet juice flavour all the way.
Perfect thanks for the explanation
