That doesn't explain why Project Cars was good with your G27, but Assetto Corsa wasn't. That just shouldn't be the case and is almost definitely something settings-related.No I meant the clunky FFB on the G27 because of the gears it uses, on the T300 it is not clunky.
I have owned a G27 and a T300 and the G27 was clunky in every game except project cars, because it has gear based FFB unlike the belt and dual motors in the T300. By clunky I mean you can easily feel the steps of the gears and also because it does not have a separate FFB motor, things like road effects and gravel on dirt rally interfere with steering.
It's especially strange because Assetto Corsa tends to be one of the better 'out-of-the-box' sims in terms of good FFB, whereas Project Cars typically takes some tweaking.
with other racers .but im starting to get the hang of the settings. thanks for that
