- 11 Sep 2013
Yup, easy ways to tell.1. When I see other craft around, is there a way to tell whether they are human or AI? I'm still not sure if that's random AI pirates or an actual human player trying to take me down.
At a distance - Humans will show up on your radar as a hollow shape (triangle if weapons are out, rectangular if stowed), whereas AI are solid/filled-in shapes.
Also, try hailing them - If you can have a chat, they're human. But as mentioned, if they're called 'CMDR [something]' then they're real live people.
Interdiction is also fairly easy - If you get stock phrases on your comms panel, like "This is going to be so easy", "Now I have you", "Prepare to die", "Hmm, what are you carrying, I wonder?", then they're probably AI. Again, you'll see the CMDR bit here too.
Your chances of being player-interdicted are higher in the more populated areas, so if you see lots of hollow shapes then it may be a player. As you're being interdicted and struggle to escape, glance down at your scanner - The interdicting ship will be in red and you can see if it's a hollow or filled shape.
YOU have not scanned it (or purchased the data from Cartography), so your personal map of the system considers it undiscovered. However, there are 400 billion systems to explore, so it's still possible that everyone has sped off into the distant unknown, completely missing the occasional local one...When I log in, am I playing in the same Galaxy as everyone else? If so, why are there so many undiscovered systems so nearby?
