Caporegime
- 18 Oct 2002
1070 for £300? Clocked beating a 980 Ti? yay!![]()
Yup, to be expected tbh (a stock 1080 to be level or beat a 980Ti and a clocked 1070 to be level with a stock 1080)
Is a 1070 for £300 a good deal?
Geforce P1 = TitanWhat do you think about naming?
Titan should go away, they used up the cool letters.
1080 is not going to happen either, doesn't sound powerful (ten-eighty); just like when they went from 980 to 280 (100 series was hidden in as OEM units).
£250Wasn't the 970 £300 on release? In that case I'd say yes!
Geforce P1 = Titan
P2 = x80Ti
P3 = x80
P4 = x70
P5+ = x60Ti
P6 = x60
Etc
Then it'd be V1 for Volta series. That'd be my idea at least.
Another idea:
Geforce Elite = Titan
501 = x80Ti
505 = x80
507 = x70
515 = x60Ti
525 = x60
551 = x50Ti
575 = x50
£250
But £300 would still be good if it outperforms a 980Ti.
I don't expect the 1070 *or whatever it's called* to surpass a 980 Ti, On par with a 980 or just behind a 980 Ti yes IMO.
If the rumoured specs are to believed I think it will.
Well a 970 (small maxwell) matched a 780 ( a big Kepler ) and that was on the same process. I am pretty confident that a lot of the high end pascal range will match or beat a 980ti. Big pascal will be a huge jump i reckon.
Or to put it another way (seen as god knows what the naming scheme will be for the cards) we will have a ~£300 card that matches/beats the 980Ti.
If the rumours are true then I'm kind of regretting getting the 980 Ti I got a few days ago even though we have roughly 8 months to go![]()
6 months!
Why? It's gonna hold a decent value and you still get 6-12 months of use out of it.
If you're going to look at it that way, why buy anything tech related?![]()
It easily beat a 780 from Day 1. Was basically on par with a Titan. With driver improvements to the GM204 group, it now beats the 780Ti more often than not.Well a 970 (small maxwell) matched a 780 ( a big Kepler ) and that was on the same process.
