I've only recently purchased the D7000 as of Saturday (3rd Oct 15) and have exactly the same problem as jambo862. I'm on latest firmware (1.0.0.18) and the router just locks up randomly with leds just solid white, unable to access admin via wifi or wired connection and unable to ping. Interestingly the WiFi still advertises but unable to connect, 5Ghz does not respond, 2.4Ghz responds with login but rejects credentials.
I have not tried the older firmware as jambo862 suggested, so may try that next.
This is strange... Corderoy and Jambo, Could you answer the following questions, as we have only seen you two report this then maybe there is something common.
They appear to have got rid of the annoying delay when first logged into, it was fine if you clicked advanced straight away but now it seems I do not need to.
