Seems quite weird, not sure if it was actually happening or not, but it seemed I could power out of initial understeer by putting my foot down more (diff was set to Auto- so a little favoured towards the rear). In other words - if I let off the power and wait for traction then it would understeer further than if I put on the power when its about to understeer.
Whats peoples thoughts on hatchback STI's? Is the engine in that suffering from the same problems as Hawks? Is the hatch very diluted from the saloon?
I drive a DC5 Honda Integra Type R at the moment but really fancy trying a performance turbo.
(I came from an FN2 Type R)I found in my 05 with DCCD if it was set all the way back if you give it some power in the corners the back will start to come round it was however rather prone to understeer and i did find you had to be quite agressive with it to make it properly side around.
EnzoSmithers - I made the same swap from a DC5 to a scooby, i really fancied trying the turbo nutter thing and im very glad i did.
Can get the back out in mine fairly easily in the wet, but then I'm 45/55 to the rear with the CVT
here is mine with a shiny new wheel refurb.
Snip
Is anybody else off to Santa Pod on Sunday for the JapShow Finale event there?
Damn I forgot about this. Not than I'm in an Impreza
Just checked and I'm working too. Its only 30 minutes away from me
Still to go before the end of the year:
Gauges
I didn't really buy into the whole Defi thing myself, couldn't see any point other than bragging points
