Man of Honour
- 29 Nov 2008
- London
iirc SIM only phones from Apple can be used with any SIM but the ones from elsewhere usually lock to the first SIM you use.
How do I find out which chip I have? I downloaded Lirum Info - even paid £2.29, and I still cannot see the CPU name.
There you go.As soon as you open the app, I got a little popup asking me to upgrade to the full version... i clicked "not now" on that and on the main page it gives you the model number.
ending AP = Samsung
ending mAP = TSMC
I wouldn't necessarily say that Samsung is 'bad', it's just less good than the TSMC.
Ah thanks. It reads N66AP. As you've been such a nice chap Feek, maybe you can tell me if that's the goody or the baddy? Save me reversing back through the thread.![]()
TSMC chip for me too - the battery life in my 6s Plus is unbelievable!
I couldn't stand 16gb anymore... will use it up very quickly... I have spotify premium too, but like offline playlists.
I was able to fill a 64GB ipad mini pretty easily... so I pick 128 now... 64 minimum for me...
