Caporegime
- 18 Oct 2002
Any sign of any >60Hz 2560x1080 monitors in the works from any of the manufacturers?
Acer Z35 Predator, due to be released early next year. Gsync and 200Hz (apparantly)
There is also now a dedicated youtube review channel for 21.9 support in games!
but if it were 200hz expect a heavy premium and on top of that gouging from the retail shops.I have a heard time believing that it is going to be 200hz.. but i would be happy to be proven wrong thoughbut if it were 200hz expect a heavy premium and on top of that gouging from the retail shops.
IIRC, that 200HZ model is going to be 35" with a res. of 2560x1080....
Each to their own but a ppi of 79 is far too low for me. Most people find it to be awful with the benq 35" 2560x1080 screen even in games....
I don't even see the point of 200HZ any way, 144/120HZ is plenty good enough, heck most people can't even tell the difference between 144 and 100 especially with g/free sync.
Well if you are a "pro" gamer or CSGO is your main game, fair enough, but I would be willing to bet that even the vast majority of cs:go players wouldn't notice the difference between 120/144hz and 200HZ unless they are ESL level and even then it is a big if.....
Comparing 30-60 is just stupid, same way comparing 60-144 is stupid, like all tech, there comes a cut off point where the difference isn't noticeable for the majority and if people do "notice" a difference, I be willing to bet it is just placebo.
Also, yes refresh rate does play a part in pixel response time but the panel has to actually have proper overdrive etc. otherwise it might actually be worse for motion clarity like previous monitors that have tried to achieve 200HZ i.e. overshoot and in some cases you might even get higher input lag
Going by this forum and many others, I would say most tech savy people (which is a large % of PC gamers) would notice the difference in smoothness/response and more so the motion clarity between 60 and 120.
Well even at 2560x1080 you are going to have a hard time pushing 200 fps in AAA titles.
Also 1080p @ 24 vs 27 is just 10 ppi, most people wont notice a difference at a normal sitting distance.
have you used both? I have, there's quite a big difference in sharpness.
Well, I moved from a 24" 16:10 1920x1200 to a 27" 1080p BENQ GW2760hs to a 29" 21:9 LG 2560x1080 and the benq was very obviously softer than the other two. my desk is 80cm deep so make of that what you will. I maintain there's an obvious difference when they are side by side and anybody should be able to notice it, really.
no, its a 29", size is measured diagonally. You might mean it has a similar height to a 16:9 23" screen, in which case you'd be right, but it's also 6.7" wider than a 23" 16:9 screen and it has 33% more screen area (physical, not desktop space).Also 29" is basically a 23".
