The GTX 980 Ti owners thread.
It will be hotter but not much 4K is the real strain its a massive jump over 6m pixels more than 1080 hence the sudden heat/noise.
I think a single GTX 980 Ti will be fine @ 1440. 4K though really needs as Kaapstad said SLI under water as a minimum for decent FPS.
Surprised your getting 75C @ 1200 though mine is only 65-67C @ 1080 in most games. I do have a 120mm side case fan sucking cool air directly over the backplate & a 2" gap all round now as I moved the card to the 2nd PCI-E slot so its on its own.
Ive gone for an ROG swift gsync monitor. 75c is on the stock fan profile but i used the same one i had with my old sli 780 setup. 65c max with it and very little noise. Tbh ive used this card very little for gaming, recently switched from a Z87 system to X99. No games currently installed as my back up hdd kicked the bucket mid build. Card is in the top slot of my msi mpower board.
My MSI 980ti Gaming was hitting 80+ @4K in the following
Mad Max
Tomb Raider
Batman
That was with 100% fan, my other (980ti SC ACX) was only hitting high 60's low 70's.
Good to hear not just me then! Getting 66C right now on Arkham Knight @ 4K thats fine but when the ambient air temps rise so does the GPU!
If you can move the card down a few slots so its directly in front of the fan blowing cool air at the backplate. This made mine a little better temps wise. Your case has plenty of room so 1440 should be great.
Theres a further two 120mm intake fans on the floor of the case, (not visible in that shot). Gotta reinstall afterburner just to see what temps are like at present. In my previous setup at stock it idled at 29c, 25c with the custom fan setting which overrides the zero fan function.
80c's considered 'normal' for a high end GPU, especially under 100% load (I think the reference 980Ti hits a thermal wall of 83c without any user modification) - I wouldn't say something is wrong, just that it isn't the best. The 6G is a very good all round card, and its fans are extremely quiet (which I'd assume is more important than heat to you after your previous post)
Hmm just trying to consider all my options.
Having said that, my room gets very hot already with my current setup. It's only a small box room :(
The reference cards cooled better in SLI than the msi's at 77c max. However they were like jet engines. Literally extremely loud and you could quite nicely toast marshmallows on the rear of your pc.
Early Xmass box 980 Ti Poseidon from SLI 4GB 670 H2o cooled as it was on sale for £620 and well impressed.
Temps are just about spot on quoted in the reviews, l usually buy a GPU and put the blocks on myself, its very easy to install.
Anyone thinking of adding a watercooled 980 Ti to thier loop look no further than the Poseidon its got looks, performance and works out cheaper.
Review- http://www.guru3d.com/articles-pages/asus-geforce-gtx-980-ti-poseidon-review,1.html
Looking good Chris, enjoy!
As for these poor temperatures being reported for the MSI 6G... I'll do some testing next week and post results, but I'm definitely not experiencing the high temperatures that others are.
I've not really read through the last few pages but what temperatures are people getting with the 6G?
Playing The Witcher 3 the past week and never seen it go above 65C. That's with the core running at 1470MHz, memory at 7500MHz, and full fan speed at 1440p with every maxxed minus Hairworks.
Full fan speed you mean always @100%?
Welcome and on TROH.:)
The Roll of Honour.
Make Asus Poseidon, OLDPHART, Link, Date 21/10/2015
Make MSI Gaming, razorpakk, Link, Date 20/10/2015
Make EVGA SC ACX, altrewin, Link, Date 19/10/2015
Make EVGA Hybrid, jc0, Link, Date 17/10/2015
Make EVGA Hybrid, delpy8, Link, Date 16/10/2015
Make MSI Gaming, AWPC, Link, Date 14/10/2015
Make Reference, C35799Gamble, Link, Date 13/10/2015
Make EVGA SC ACX, whyscotty, Link, Date 13/10/2015
Make EVGA FTW ACX, delpy8, Link, Date 13/10/2015
Make EVGA SC ACX, Uncle Petey, Link, Date 13/10/2015
Make KFA2 HOF, loco, Link, Date 12/10/2015
Make Gigabyte G1, razorpakk, Link, Date 09/10/2015
Make EVGA SC Ref, bimbleuk, Link, Date 09/10/2015
Make EVGA SC Ref, tyler_jrb, Link, Date 09/10/2015
Make MSI Gaming, seanyc5, Link, Date 08/10/2015
Make Asus Strix, drex69, Link, Date 07/10/2015
Make Asus Strix, Joe!, Link, Date 05/10/2015
Make KFA2 HOF, Intra-Agnostic, Link, Date 02/10/2015
Make KFA2 HOF, ratters, Link, Date 01/10/2015
Make Palit Super Jetstream, Watlinguk, Link, Date 30/09/2015
Make EVGA Classified, Dicehunter, Link, Date 30/09/2015
Make EVGA SC ACX, ashjones86, Link, Date 30/09/2015
Make Gigabyte G1, [Death], Link, Date 27/09/2015
Make Inno3D Hybrid, Porl, Link, Date 25/09/2015
Make MSI Gaming, evilmatt, Link, Date 24/09/2015
Make Inno3D Hybrid, Hiijinx, Link, Date 09/09/2015
Make OcUK Tech Labs, offmyed, Link, Date 08/09/2015
Make Inno3D Hybrid, Boomstick777, Link, Date 07/09/2015
Make Gigabyte G1, uscool, Link, Date 06/09/2015
Make MSI Gaming, Awahwah, Link, Date 06/09/2015
Make EVGA SC Ref, Bozzler, Link, Date 05/09/2015
Make Palit Super Jetstream, lowrider007, Link, Date 04/09/2015
Make MSI Gaming, JABenedicic, Link, Date 03/09/2015
Make Zotac AMP Extreme, PakJai, Link, Date 03/09/2015
Make EVGA Classified, supermoose1111, Link, Date 03/09/2015
Make EVGA SC ACX, IceWolf, Link, Date 03/09/2015
Make MSI Gaming, anticonscience, Link, Date 02/09/2015
Make Palit Super Jetstream, artus, Link, Date 01/09/2015
Make Zotac AMP Extreme, Muzza1875, Link, Date 29/08/2015
Make Reference, Mysterae_, Link, Date 29/08/2015
Make Asus Strix, andybird123, Link, Date 29/08/2015
Make MSI Gaming, andybird123, Link, Date 29/08/2015
Make Palit Super Jetstream, ryryryan, Link, Date 28/08/2015
Make MSI Gaming, traveyb, Link, Date 28/08/2015
Make EVGA Classified, Alisdair, Link, Date 27/08/2015
Make KFA2 HOF, Gudu55, Link, Date 27/08/2015
Make MSI Gaming, davewhite04, Link, Date 27/08/2015
Make Zotac AMP Extreme, Ravenger, Link, Date 21/08/2015
Make Palit Super Jetstream, Aretak, Link, Date 20/08/2015
Make KFA2 HOF, McNappa, Link, Date 19/08/2015
Make EVGA ACX, Saftlad, Link, Date 19/08/2015
Make KFA2 HOF, SeanDrake, Link, Date 18/08/2015
Make Zotac AMP Extreme, ntemples1, Link, Date 17/08/2015
Make Palit Super Jetstream, DustyMiller, Link, Date 16/08/2015
Make MSI Gaming, duey33, Link, Date 15/08/2015
Make MSI Gaming, felton1592, Link, Date 15/08/2015
Make KFA2 HOF, kablooey, Link, Date 14/08/2015
Make Reference, barmyllama, Link, Date 13/08/2015
Make EVGA Classified, zia, Link, Date 12/08/2015
Make MSI Gaming, Ali_Carns, Link, Date 12/08/2015
Make Reference, jrodga2k5, Link, Date 11/08/2015
Make Reference, Boomstick777, Link, Date 09/08/2015
Make Palit Super Jetstream, iB CoMpL3XiTy, Link, Date 07/08/2015
Make Asus Strix, Gerard, Link, Date 07/08/2015
Make MSI Gaming, altus, Link, Date 05/08/2015
Make MSI Gaming, PrinceNelson, Link, Date 05/08/2015
Make Inno3D X3, dan76, Link, Date 04/08/2015
Make EVGA Classified, Tommy_Here, Link, Date 04/08/2015
Make MSI Gaming, Arcane, Link, Date 02/08/2015
Make EVGA Classified, VEGACORTEZ, Link, Date 02/08/2015
Make MSI Gaming, evsknight, Link, Date 01/08/2015
Make Zotac AMP Extreme, Navin, Link, Date 01/08/2015
Make MSI Gaming, Arkie, Link, Date 31/07/2015
Make MSI Gaming, Superpatsy, Link, Date 31/07/2015
Make Inno3D Hybrid, Minarva, Link, Date 30/07/2015
Make Inno3D X4, rolypolyman, Link, Date 29/07/2015
Make Inno3D Hybrid, ghutchison14078, Link, Date 29/07/2015
Make Zotac AMP Extreme, marcus2704, Link, Date 29/07/2015
Make Inno3D Hybrid, GoblinKingUK, Link, Date 29/07/2015
Make EVGA Kingpin, Brutus, Link, Date 28/07/2015
Make KFA2 HOF, Adzassin, Link, Date 27/07/2015
Make MSI Gaming, FMTopfan, Link, Date 24/07/2015
Make MSI Gaming, majnu, Link, Date 23/07/2015
Make Zotac AMP Extreme, Frenzy, Link, Date 23/07/2015
Make Zotac AMP Edition, CEUOTC, Link, Date 22/07/2015
Make MSI Gaming, OvEr_KiLL, Link, Date 20/07/2015
Make MSI Gaming, anewhope, Link, Date 19/07/2015
Make MSI Gaming, KLM, Link, Date 17/07/2015
Make MSI Gaming, Devious, Link, Date 17/07/2015
Make EVGA SC ACX, Temp.sgk, Link, Date 16/07/2015
Make Zotac AMP Extreme, beasty54, Link, Date 16/07/2015
Make Zotac AMP Extreme, Yulaw, Link, Date 16/07/2015
Make Asus Strix, PurE GaminG, Link, Date 15/07/2015
Make Gigabyte G1, String, Link, Date 14/07/2015
Make Palit Super Jetstream, Spit, Link, Date 14/07/2015
Make Gigabyte G1, McShave, Link, Date 13/07/2015
Make MSI Gaming, Boomstick777, Link, Date 12/07/2015
Make Zotac AMP Extreme, beasty54, Link, Date 11/07/2015
Make EVGA Classified, kael13, Link, Date 11/07/2015
Make Zotac AMP Extreme, currob, Link, Date 10/07/2015
Make Zotac AMP Extreme, Metalface Mark, Link, Date 10/07/2015
Make MSI Gaming, Mallers, Link, Date 09/07/2015
Make MSI V1, samcat, Link, Date 09/07/2015
Make MSI Gaming, Jeps, Link, Date 08/07/2015
Make EVGA Hybrid, F1aw1ess, Link, Date 07/07/2015
Make Zotac AMP Edition, sunn, Link, Date 06/07/2015
Make EVGA Hybrid, DVR, Link, Date 06/07/2015
Make MSI Gaming, Firefox35, Link, Date 05/07/2015
Make MSI Gaming, 40Four, Link, Date 03/07/2015
Make MSI Gaming, Ghosteh, Link, Date 03/07/2015
Make MSI Gaming, arknor, Link, Date 02/07/2015
Make Reference, amigafan2003, Link, Date 02/07/2015
Make Reference, savagesam117, Link, Date 01/07/2015
Make Gigabyte G1, Combat Fighter, Link, Date 01/07/2015
Make OcUK Tech Labs, NoobCannon, Link, Date 01/07/2015
Make EVGA Hybrid, Joe_Easy, Link, Date 01/07/2015
Make Inno3D Herculez, IceWind, Link, Date 01/07/2015
Make Gigabyte G1, Ashley Jordan, Link, Date 01/07/2015
Make Reference, colinmcr, Link, Date 30/06/2015
Make Gigabyte G1, Doco, Link, Date 30/06/2015
Make Zotac AMP Edition, digitalx, Link, Date 30/06/2015
Make Gigabyte G1, Robzere31, Link, Date 30/06/2015
Make MSI Gaming, Five.Stars, Link, Date 29/06/2015
Make Gigabyte G1, Fire_fly, Link, Date 29/06/2015
Make MSI Gaming, Radeon123, Link, Date 29/06/2015
Make MSI Gaming, setter, Link, Date 29/06/2015
Make Gigabyte G1, plazyma, Link, Date 29/06/2015
Make Gigabyte G1, rossiboy001, Link, Date 29/06/2015
Make Reference, toodoo9011, Link, Date 29/06/2015
Make Gigabyte G1, rootz, Link, Date 29/06/2015
Make EVGA Hydro Copper, dceightfive, Link, Date 29/06/2015
Make EVGA Hybrid, SaintJimmy, Link, Date 28/06/2015
Make MSI Gaming, Spokwiththeears, Link, Date 28/06/2015
Make Reference, goochinbuda, Link, Date 28/06/2015
Make Inno3D X3, Newu_boy, Link, Date 28/06/2015
Make MSI Gaming, Wyrdo, Link, Date 28/06/2015
Make MSI Gaming, gt11, Link, Date 27/06/2015
Make Zotac AMP Edition, DBT85, Link, Date 27/06/2015
Make Gigabyte G1, Rivod, Link, Date 27/06/2015
Make MSI Gaming, Milky1, Link, Date 27/06/2015
Make EVGA SC ACX, fornowagain, Link, Date 27/06/2015
Make Zotac AMP Edition, Angerer, Link, Date 27/06/2015
Make EVGA Hybrid, alexp999, Link, Date 27/06/2015
Make MSI Gaming, ubersonic, Link, Date 27/06/2015
Make MSI Gaming, lnoton, Link, Date 27/06/2015
Make Zotac AMP Edition, Type_R, Link, Date 27/06/2015
Make Reference, Wrxengland, Link, Date 27/06/2015
Make Zotac AMP Edition, agt, Link, Date 27/06/2015
Make EVGA SC ACX, Scramz, Link, Date 26/06/2015
Make Inno3D X3, Cavallino, Link, Date 26/06/2015
Make MSI Gaming, LauraLC, Link, Date 26/06/2015
Make Reference, Winnter, Link, Date 26/06/2015
Make Reference, Clov!s, Link, Date 26/06/2015
Make MSI Gaming, titaniumx3, Link, Date 26/06/2015
Make Zotac AMP Edition, PowerPie5000, Link, Date 26/06/2015
Make EVGA SC ACX, thefogo, Link, Date 26/06/2015
Make Zotac AMP Edition, mufc802, Link, Date 26/06/2015
Make EVGA SC ACX, GeneralD, Link, Date 26/06/2015
Make Zotac AMP Edition, Rossi~, Link, Date 26/06/2015
Make MSI Gaming, tyler_jrb, Link, Date 26/06/2015
Make Zotac AMP Edition, picnic, Link, Date 26/06/2015
Make MSI Gaming, DeanT77, Link, Date 26/06/2015
Make MSI Gaming, Brutos, Link, Date 26/06/2015
Make Zotac AMP Edition, Buck890, Link, Date 26/06/2015
Make MSI Gaming, se_vietboi, Link, Date 26/06/2015
Make Reference, Cottee, Link, Date 26/06/2015
Make EVGA SC ACX, ZeroG, Link, Date 26/06/2015
Make EVGA SC ACX, clone, Link, Date 25/06/2015
Make MSI Gaming, GiB, Link, Date 25/06/2015
Make Inno3D X3, rootz, Link, Date 25/06/2015
Make Inno3D X3, Khorvos, Link, Date 25/06/2015
Make Reference, amigafan2003, Link, Date 25/06/2015
Make Inno3D X3, theor14, Link, Date 25/06/2015
Make Inno3D X3, rickyjb, Link, Date 25/06/2015
Make Reference, floatindolphin, Link, Date 24/06/2015
Make Reference, eviljester91, Link, Date 23/06/2015
Make Reference, KillBoY_UK, Link, Date 23/06/2015
Make Gigabyte G1, Kered_Dub, Link, Date 23/06/2015
Make Gigabyte G1, Wrinkly, Link, Date 22/06/2015
Make Gigabyte G1, ronnie136, Link, Date 22/06/2015
Make Gigabyte G1, WHAT21A, Link, Date 22/06/2015
Make EVGA SC Ref, Divine Pain, Link, Date 22/06/2015
Make Gigabyte G1, AhadielGames, Link, Date 22/06/2015
Make Gigabyte G1, Shivji, Link, Date 20/06/2015
Make Reference, M1keMK, Link, Date 18/06/2015
Make EVGA SC ACX, ihatelag, Link, Date 18/06/2015
Make Reference, Diuz, Link, Date 18/06/2015
Make Reference, C3PO, Link, Date 18/06/2015
Make Reference, psychas, Link, Date 18/06/2015
Make Reference, MasterOC, Link, Date 18/06/2015
Make EVGA SC ACX, Malesu, Link, Date 17/06/2015
Make EVGA SC ACX, Mayh3M, Link, Date 17/06/2015
Make EVGA SC ACX, IT Troll, Link, Date 17/06/2015
Make EVGA SC Ref, jetpaczx, Link, Date 17/06/2015
Make Gigabyte G1, youdsy, Link, Date 17/06/2015
Make Gigabyte G1, HidYn, Link, Date 17/06/2015
Make Gigabyte G1, Matthew89, Link, Date 17/06/2015
Make Gigabyte G1, delpy8, Link, Date 17/06/2015
Make EVGA SC ACX, Axekickjack, Link, Date 17/06/2015
Make EVGA SC ACX, ArnieRambo, Link, Date 16/06/2015
Make EVGA SC ACX, agnes, Link, Date 16/06/2015
Make EVGA Hydro Copper, Giggz, Link, Date 16/06/2015
Make EVGA Hybrid, Muska, Link, Date 16/06/2015
Make EVGA Hybrid, is149, Link, Date 16/06/2015
Make Reference, The Mad One, Link, Date 15/06/2015
Make EVGA SC ACX, Valenni, Link, Date 15/06/2015
Make EVGA SC ACX, OldBoy75, Link, Date 15/06/2015
Make EVGA Hybrid, shiver, Link, Date 14/06/2015
Make Reference, ICEx21, Link, Date 14/06/2015
Make Reference, varkanoid, Link, Date 13/06/2015
Make EVGA SC ACX, JunglistE, Link, Date 13/06/2015
Make Reference, Gripen90, Link, Date 12/06/2015
Make Reference, Strife212, Link, Date 11/06/2015
Make Reference, saintdefender, Link, Date 11/06/2015
Make Reference, crazy8s, Link, Date 10/06/2015
Make Reference, Tom Martow, Link, Date 10/06/2015
Make Reference, rpggamesplayer, Link, Date 10/06/2015
Make Reference, toon_mad, Link, Date 10/06/2015
Make Reference, jjgreenwood, Link, Date 10/06/2015
Make Reference, Razor Time, Link, Date 10/06/2015
Make Reference, SeeNoWeevil, Link, Date 10/06/2015
Make Reference, RyanF, Link, Date 09/06/2015
Make Reference, roozor, Link, Date 09/06/2015
Make EVGA SC ACX, perosus, Link, Date 09/06/2015
Make Reference, ZombieDescartes, Link, Date 09/06/2015
Make Reference, Techen, Link, Date 08/06/2015
Make Reference, Rap1D, Link, Date 06/06/2015
Make Reference, khemist, Link, Date 06/06/2015
Make EVGA SC Ref, ciggybumly, Link, Date 05/06/2015
Make EVGA SC Ref, N19h7m4r3, Link, Date 04/06/2015
Make Reference, queeg, Link, Date 04/06/2015
Make Reference, abaddon, Link, Date 03/06/2015
Make Reference, Volv, Link, Date 03/06/2015
Make Reference, Larcwide, Link, Date 02/06/2015
Make Reference, a66as, Link, Date 02/06/2015
Make Reference, Angst, Link, Date 02/06/2015
Make Reference, RichardH754, Link, Date 02/06/2015
Make Reference, Phixsator, Link, Date 01/06/2015
Make Reference, Tommy_Here, Link, Date 01/06/2015
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your 980 Ti.​
