Not at all. They quoted me £220 when I booked it in 5 weeks ago, and the service guy said "we've not serviced one yet, so it may be more." okaaaay.. Ended up costing me £191. Changed oil/oil filter and air filter. Adjustments and lube, usual things. May have had a software update too as I know they're checked during servicing. I begrudge it though as I always do work myself, but it's under warranty, so...
then I was carrying a little too much speed behind a lorry and almost had my back wheel in line with my front when he braked
Didn't have a great start to my morning, first I tried to zip my new jacket up using the outer zip and the lining zip queue 10 minutes of swearing and flapping about until I realisedthen I was carrying a little too much speed behind a lorry and almost had my back wheel in line with my front when he braked
Apart from that I had a nice commute, the only downside to the Furygan Titan jacket is for whatever reason they decided that the zips used to do your cuffs up didn't require a proper sized zipper and they've used some tiny little daft thing that you'd have no hope of doing up in winter gloves, so I had some keyring rings lying around one of those attached to each zipper and we're away nice and easy.
Ignoring that it's a great jacket warm, comfy and doesn't ride up leaving me with a freezing cold lower back. It looks like I'll be testing how waterproof it is on the way home tonight.
I just need to remember to zip my vents up or else I'll be moaning it's not waterproof without realising I'm an idiot.
) and doing the zip up at the same time.
Richa Rain Warrior: http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/33286
They're nice and long, so will cover your boots when you sit on the bike. Remember, if you end up buying from a shop, then make sure they're quite long!
could fit 2 legs into each side lol!
Had these turn up today, wow are they baggycould fit 2 legs into each side lol!
I ordered a pair ages ago, had to send them back because they were FLOL long I easily could have stuck another half a leg onto the bottom of mine and then they might have been about the right length.
I just use a pair of high gear ones I bought for work from Go Outdoors ages ago, do the job perfectly.
Dunno about standard waterproof trousers? Surely bike ones will be better sealed to still work at speed whereas standard ones would just be built to withstand weather walking about?
just need to give it a good scrub before lubing it up with the new stuff
