- 5 Sep 2011
- Surrey
I'm going to show you something later.....
PS: turn off G-Sync.
Are you, on what - your system?
I don't have G-Sync. I'm at 4K 60hz with V-Sync disabled.Please remember that any mention of competitors, hinting at competitors or offering to provide details of competitors will result in an account suspension. The full rules can be found under the 'Terms and Rules' link in the bottom right corner of your screen. Just don't mention competitors in any way, shape or form and you'll be OK.
I don't have G-Sync. I'm at 4K 60hz with V-Sync disabled.I'm going to show you something later.....
FPS top right
You see this still isnt right, even with your spec there are drops down from 90 fps to 60 and back again, for no apparent reason, no extra detail on screen etc.
Then you just extrapolate that out to people with slightly lesser hardware, and the game is still a mess.
Me for example with a boosted 970 and an overclocked I5 2500K and 16GB of RAM still get frequent drops even with fancy stuff turned off at 1080p.
Will it ever be fixed? I think if you throw enough hardware at it you can make it seem playable, but is it just engine issues that will never play nice on PC?
Not being funny but to put that into perspective, I spent less than £600 minus the GPU putting together a small box for my brother last year for 1080p, and even that has a 4600k. Low minimums on a 2500k in 2015 isn't all that shocking of an occurrence I'm afraid to say. Even if the game isn't a mess.
Game seems to be broken still for me. Re-installed it last night and can't tell if its on the latest build or not... Not sure how to check on steam.
The game caps at 60 for me even with v-sync off. The after a few minutes the fps will plummet from a solid 60 to 30-35fps. To fix it I have to minimise the game and then maximise it... anyone else had this issue?
Edit - Fixed it by changing the game settings in nvidia control panel to v-sync off and power to max performance...
If the any of the four cores were maxed out i would agree with you, they sit at around 50% utilised the whole time....
Actually having said that, i checked the the 4690K is less than 10% faster than the 2500K, really that doesnt mean much.
We are very sorry that many of our customers continue to be unhappy with the PC version of Batman: Arkham Knight. We worked hard to get the game to live up to the standard you deserve but understand that many of you are still experiencing issues.
Until the end of 2015, we will be offering a full refund on Batman: Arkham Knight PC, regardless of how long you have played the product. You can also return the Season Pass along with the main game (but not separately). For those of you that hold onto the game, we are going to continue to address the issues that we can fix and talk to you about the issues that we cannot fix.
Thank you,
Warner Bros Interactive Entertainment
It works fine for me, see my videoSo, refund and get this on the PS4?
Or will my SLI Titan X's do it justice?
