- 18 May 2010
Tablet mode works great for a media pc, thanks
The big release on the 10th:
http://www.theverge.com/2015/11/5/9676976/microsoft-windows-10-fall-update-released-to-testers
Has anyone got this build (10586)?
Is there a way to set a custom mouse pointer size, or at least add in a higher DPI mouse point graphic?
I have my secondary 1080p screens on DSR to 4k and 125% scaling and the mouse pointer is massive on these screens!!
I cant have it on anything under 4k though as the text gets super distorted
Is there an ISO available yet that allows a clean install using existing W7 & W8 product keys?
Yep. Well more like what it should have been released like, or almost there.
Any idea how to access and edit addresses in Windows 10 Mail?
Andi.
1080p screen at 4x DSR? Why can't you run at 1080p? Don't know why text would he distorted?
Sadly, I don't believe it can be done.
If its an online account (gmail/outlook/hotmail etc) do it in their web clients.
Other than that, you'll need Outlook, not Mail.
Just to ask for sure, will I lose my license/require reactivation if I upgrade my laptop ?
I have RAM on the way to go from 6>8GB, and I'm tempted to order a quad core i7 ( currently on dual core i5 with HT).
As I've read about people losing activation even with just a mere bios update. If a cpu change makes the license imvalid I might as well just install KMSPico to get around the retarded DRM. As I can't be arsed to reinstall Win 7 with my original licence, then upgrade to win 10 again, for nothing.
check the key is definitely present in the bios, then reactivate for you.
