- 6 Jan 2013
- Rollergirl
I've just bought a Dell 27inc Gsync...and it's not mind blowing...
Before that I had a Dell ultrawide 34 inch ...
Running around the same place @ 100 fps is no different on the dell Gsync than running around the place @ 60 fps ....on the dell UW TBH...
It's when you're running around at 97fps, or 63, 71... etc
That's when the magic works. If a game sits locked at your max monitor refresh rate and your GPU can keep pumping out the frames, then Gsync isn't really being called to work.
