- 30 Nov 2011
the problem with the power brick is usually that it won't power up without unplugging and plugging it back in, only doing 24hz and then refusing to work altogether sounds like an RMA job
Looks like it. Started of by only being able to run at 24Hz. Tried another DP cable but still no luck. Then it proceeded to show no image at all. I've borrowed another power brick from a mate to try today as I've seen some users report issues with the supplied one. Many have purchased Asus laptop power bricks which are compatible. But I'm not holding out much hope.
Do you know which Asus laptop power brick works? Just in case my Asus ROG swift power brick packs up,
I cant link it as it would fall under competitors. But the model no is.
ADP-90MD BB
Gutted you are still having probs Rob![]()
from what I hear they're both very good and most people think they are a game changer.What advantage does Freesync have over Gsync?
I'll be hopefully able to confirm how good gsync is soon. My swift is alive and all resolutions are available. New power brick and DP cable seem to have sorted it. But ill wait and see how it pans out before I'm certain its a long term fix.
Indeed, seems to be a combination of a new power brick and DP cable that has sorted it. Hopefully thats it for good. Had a wee quick blast on bf3 just now. Feels so much better compared to 60Hz.Holy ****!!!! No way man!?? That's awesome news!!!
Indeed, seems to be a combination of a new power brick and DP cable that has sorted it. Hopefully thats it for good. Had a wee quick blast on bf3 just now. Feels so much better compared to 60Hz.![]()
60Hz just isn't enough anymore lol
