Batman™: Arkham Knight Performance
Just being brave and bought this game...
run it at 1440p with my Fury, all maxed out, run the benchmark I can see there are some shutters already, min 5x fps max 1xx fps, avg is 80fps, with freesync on.
It shutters quite badly especially when I drive in full speed, the fps could drop to 2x - 3xfps during those scene, quite disappointed, maybe I need to lower the setting and lets see what will happen.
If you haven't already make sure to turn the Gameworks features off that are selectable with AMD cards and also anti-aliasing as it doesn't do much.
Well if you installed it yesterday your game might have already had it applied.
But steam downloaded an update of 2.2 GB and I checked the patch notes and it was brand new. By all accounts it does help with the stutter.
I actually downloaded it on Monday night so I might not have it, and when I played it yesterday night I didnt see any update message from steam, got to check it again tonight, thanks!
Totally inaccurate.
If I had no GPUs at all and I only gamed on an ancient phone my opinion would still be the same.
"This NVidia sponsored game is broken with no 2 way SLI support."
Perhaps you could make your next post about this broken game rather than speculating about peoples hardware and future buying decisions.
Sounds like you may be happier sticking to AMD and playing games that do not have Nvidia effects in them.
How do I check do I have the latest update or not?
I cant see the version reference at the bottom corner (usual)
I would be happier seeing game devs publishing games that work properly on both AMD and NVidia hardware.:)
I remember before the arrival of the internet when games tended to work first time. Why have things gone backwards ?
+1
The internets made devs lazy, They know they can release a half baked game, Get away with it and send out patches at a later date.
I miss the days of putting in a disk, Installing and just playing :(
For as long as I can remember games have always had some fault or another and I have been gaming since the Spectrum 48K release date. :D
Batman: Arkham Knight - PC Update November 24th Changelog:
Fixed a hitch during some game saves
Fixed a Windows 10 issue causing the game to be unresponsive on launch when the keyboard language was set to Japanese, Japanese Microsoft IME, Korean, Chinese (Traditional) or Chinese (Simplified)
Fixed minor delay when aiming a gadget when playing with a keyboard and mouse
Fixed a bug causing full screen movies to play at half the monitor’s refresh rate on some systems
Fixed players sometimes not being able to counter the Mini-Gun Brute after being spotted when playing as Nightwing or Batman
Fixed a performance drop that occurred when encountering Man-Bat for the first time
Fixed some Multi-Monitor specific bugs
Some improvements to mouse and keyboard bindings
Improved VRAM management to reduce framerate hitches
Stability improvements for rare crash issues
Fixed an issue causing certain types of lights & shadows to render incorrectly
Fixed an issue causing the game process to occasionally remain running in the background for a period of time
Fixed the Knightfall Protocol not being able to activate under certain conditions
Fixed a progression blocker that could occur in Stagg Airships when leaving the predator room after only knocking out one of the guards
Fixed damage states for Batman’s V8.03 skin in Story Mode after selecting an alternate skin for AR Challenges
Fixed missing rain effects on several Batman skins (fix for 1970s and Arkham Origins skins coming soon)
Added support for new DLC releasing on November 24th
Play as other characters in AR predator challenges
First time playing this game. With all the reports of performance I stayed away till fixed. I thought I would give this ago and to my surprise the game runs very smooth. @1440p I needed to switch of the GameWorks effects but in truth I find it hard to notice what they really even add over being off.
@1080p I can switch these on and keep a solid 60fps locked.
Does the game get more demanding or something later into it?
1440p - recorded @720p 60fps
You done much batmobile driving? That seems to be where the problems are.
But i've never had a problem with the game as a whole, driving can be a bit odd at times. And they game me all the other games for enjoying this game so much :D
This right at the start of the game not had a chance to try Batmobile. Do you get this early on?
