- 22 Feb 2008
You need to buy a docking computer which takes up a slot on your ship. I've never had need for one myself.
Left hand targets panel, you can select and target anything and everything in system from the list in the first tab, there is also a bindable 'previous target' or 'nav target' option in the controls, I can't recall what the exact term is now but it will allow you to swap back to the previous navigation target though it is a little buggy at times.
Yup, standard docking computer available in outfitting, internal slots. That said, you will soon get used to where the pads are, once inside a station your compass will point to your pad, outposts, if you can't see it just fly past and check the other side, very rarely will it not be visible and again, you will get used to the rough layout of pads.
Thanks, folks.
I think this game is going to eat up a lot of my life, now!
