I've had to download 74gb tonight for this and it's just crashing to desktop every time I load the gamesucks.
PTU Patch 2.0g just dropped now apparently if you wanna download some more, I'm skipping a few until someone tells me its stable
2.0 PTU is only 30GB, unless you downloaded the live 1.3 as well, but you didn't need to if you just want to test 2.0.
What resolution are you running it at? lower them if it's 4K or 1440P.
I tried getting into anything other than the hangar in PTU tonight, just wouldnt' connect, hangar was fine (I'm not a fan of the current FPS movement, feels more clunky than before) but at least hangar worked.
Holding off on a new GPU purchase for this. I have 280x Crossfire at the moment but I'm sick of all the BS and faffing around with crossfire, to the point where I haven't played a PC title in the last year pretty much.
Does SC seem to favour nVidia or AMD? I'll be holding out for next gen cards next year anyway, but just curious.
Also, can't login to PTU website to see forums, just doesn't do anything when I click register.
PTU H build is out now. I'll test it for FPS as soon as it finish downloading.
Heres some gameplay on G build:
In that build i got an average 30fps at every resolution no matter if its 1080p/1440p or 3200x1800
Wills see if H is better
Is 2.0 out now ? Looking great gonna be fab when full game is out![]()
Still on PTU. I imagine it needs another 2-3 patch to go live. They made huge improvement in a short time tho. At first you even logging in was a hit or miss process, now i can usually log in on the first try and play for an hour without crash.
