Seems fine over DP from my computer though i can't get it to go to 60Hz, did someone say there was a setting in the OSD that needed changing?
in the osd menu go into the setup menu at the bottom then change the dp format from 1.1 to 1.2
I would put before and after pics up but I don't have any hosting.
Mine arrived this afternoon - so far so good! (Edit) - Adding before/after pics to the bottom.
I can confirm it does do 4k at 60Hz over HDMI in the first port only. I connected my PC via HDMI from a HDMI2 port and it automatically selected the right resolution. Over DP I've only got 4k at 30Hz from my work laptop but I suspect thats a limitation with the Lenovo X250.
PQ in 4k - I've not got a lot to compare it against but once you turn the brightness down a little and change it from the default 'user' color setting it looks good - out of the box it's way too bright and washed out. I don't notice any flickering.
Desktop real-estate - loads! The problem is it's quite a heavy monitor. It's a few 100g heavier than my Ergotron LX desk mount is designed for and at least 10" too big - had to order a VESA 200x200 adapter to make it fit at all - more weight. When I'm playing games or watching TV/Films I'll sit back a bit but it would be nice to pull it forward when working as text can be a bit small. I've tightened the arm as much as it will go but it does slowly drop when extended and sometimes makes some odd noises
Windows 10 scaling is still a bit poo - standard Windows apps seem to work quite well but 3rd party software ends up with a mix of enlarged text and 1:1 buttons etc.
Upscaling
Out of the box it applies a lot of smoothing to 1080p content. Messing around with AC:Syndicate I didn't notice any appreciable difference between nVidia GPU based scaling or display scaling. It does have a feature in the picture menu called 'X-Res technology'. Setting it to 'medium' sharpens things up considerably. It's no miracle worker - you'll need to sit back at normal 40" TV distances for a good 1080p picture - but I prefer the sharpness with X-Res enabled to the default even if the jaggies stand out way more. I tend not to play twitch reaction shooters any more - getting too old for that! No idea what the lag situation is but I don't notice it in Fallout 4 or AC Syndicate.
I tried AC:Syndicate on 4k Very High preset using a 980Ti - looks like it managed 20fps. Given that AFAIK SLI scaling isn't linear you would need 3 to get anywhere near a 60 average. I am running an old 2600K stock clock but I'm not sure the CPU makes an awful lot of difference so long as you've got more cores than a console.
If anyone has any other questions feel free to ask.
Before:
After:
Would someone who's received one mind trying out the steps shown inand report back their findings, maybe take a few photos? I'm curious to know whether as it's the same panel, it has the same problems.
I think we've confirmed it's not for photo or video editors![]()
Much obliged, thank you! If it's not trying your patience too much, could you try scrolling a Word document (white background, black text) and let me know how bad the ghosting is? On the Philips the white-black transitions are shocking, but maybe I've been spoilt by using Dell 3008WFPs for so long.
? Or at least weigh the supplied stand separately so we can deduct that and get a better idea?PQ in 4k - I've not got a lot to compare it against but once you turn the brightness down a little and change it from the default 'user' color setting it looks good - out of the box it's way too bright and washed out. I don't notice any flickering.
[/SPOILER]
Wow, just seen that youtube video, if my monitor was like that it'd be going straight back!The fact it displays the same issues at the Phillips () is a little worrying, but I imagine not all specimens exhibit that behavior, just a few 'bad' panels?
If anything the only problem I had with mine out of the box is a slight warm red cast which was easily removed by calibrating it.
What settings have you got on yours for colour and brightness etc?
Total boxed weight according to the label on the delivery tag is 14.5Kg. I just put the stand on the kitchen scales (it's basically two small metal 'legs') and they weigh in at 250g. You have to take the cables, manuals etc off that as well. It is a heavy monitor and it's not helped by the fact that the hard points where the stand connects are solid metal, not removable and protrude from the bottom. There's no way I'm unmounting the monitor now to weigh it after the hassle and squeaky bum moments involved it mounting the thing to start with so sorry! It wouldn't surprise me if Iiyama's weight was accurate - my monitor arm has been tightened to as tight as it will go and struggles when the monitor is pulled forward - it's rated up to 11.5Kg.One last request if anyone is willing!? Ilyama states the weight as 12.2Kg! That's very heavy compared to other 40" 4k screens (The Phillips, and various TV's come in at between 8kg and 10kg as far as I can tell). Is that it's total boxed weight, or including the supplied stand?
Is anyone able to weight this thing and see if that's accurate by standing on some bathroom scales with it? Or at least weigh the supplied stand separately so we can deduct that and get a better idea?
Thanks all!
Rich
