How so ?
BS POST.
If its like the other high refresh VAs then is it not actually 100Hz (which is still pretty good) with some technique to boost the motion clarity "as if" you had a true 200Hz panel?
If it truly takes a 200Hz signal and presents it at an appropriate level that is quite impressive.
This. I was wondering why to even bother clocking it to 200. For an IPS/VA doesn't make much sense to me, it assumes a stable response time of 5ms which simply won't happen and you surely will get into a worse experience than say 100 (perfect for IPS/VA imho) or 144 (this is overkill already).It is a native 144Hz panel and is overclocked to 200Hz. There is no motion clarity boosting going on. Although one might question whether the response times are optimal for such refresh rates (they're not - at least not all are).
The much steeper curve is perhaps what Virtua was getting at here. Which makes a significant difference to the experience.
Yes that's it exactly - that post of the visual comparison of the x34 and z35 really shows it. It fills your field of vision.
Forum post won't let me attach for some reason - the attach icon has a red cross through it?
Test
http://imgur.com/xCSpiqn
You get a good feel for the curve on this shot and the colours - I had the brightness set about 30.
What price were you thinking? Seems you're clearly interested in it.
