My 4K smart TV has netflix and prime apps on it. Is there any benefit to getting the 4K TV box over them?
No need at all for the firetv when you have a smart tv.
hi,
juts confused where is the firestarter button, how i install this
Get the IP of your stick.
Download ADBFire and run
Go into SETTINGS and put your IP in.
CONNECT.
Download TVMC (this is Kodi with extras)
Click on the button that says INSTALL APK
Choose TVMC
Wait until it is installed.
Go and try it out of your Fire Stick SETTINGS > APPLICATIONS
Then
Click on the button that says FIRESTARTER
Wait until it's installed
Go to Fire Stick and open it up from SETTINGS > APPLICATIONS
Set it up so a double home click starts TVMC.
I've got all my four devices opening TVMC on a double click and opening Firestarter on a single click.
A single click will show all your APPS you've loaded and you can also get to the Home screen if you want.
The only downside to not having the FireTV over your Smart TV is you won't have Kodi on it.
Replace TVMC (oh the shame) with installing a decent build and i'd agree with SGF but the tvaddons stuff is not really that great, you'll be amazed how much more you're missing out on if you broaden your horizons a little.
There's a few things I want to watch on catchup but my god I really can't be bothered to swap over to my AppleTV and use hideous airplay from my other phone
Such as?
To be honest I haven't used the extra bits of TVMC but I've messed a bit.
I'd suggest having a look at theblackboxostv - it's a UK specific build with a LOT more going on than the TV Addons build.
Anyone have any suggestions for settings in Kodi? I'm getting a lot of slowdowns (like fps drop) and audio sync issues.
Yeah, TV shows too.
I had the same issue, what size TV are you using? I know it's strange but on a 32" mine played fine, on my 50" I had stuttering on every video and TV show I tried to play. Couldn't find a fix for it so I sold it on.
Is this using an addon? Try using another one if so
Have you any idea how I can add my hard drives to this build?
I've been all over it and can't find an ADD SOURCE or similar.
