Hey guys, I'm finally going to make my first proper recipe today.
Can someone check my percentages here for a 5ml sample of apple pie. I've used Danneh's recipe, (the diluted one), plus added the Apple and Cookie using his suggested 4:3:1 ratio.
http://forums.overclockers.co.uk/showpost.php?p=28868557&postcount=9992
Do my figures look correct?
The cinnamon and marzipan though are coming out at 0.01grams, and though my scales are meant to go down to 0.01, I can only get them to read 0.03 lowest, so maybe I should leave those two out, or take a chance and add a drop for each and maybe blow my head off?
I'm using all FA concentrates btw. Thanks.
snip[/QUOTE]
Don't use that calculator man, it's crap unless you put in all the specific weights.
Use [url]http://e-liquid-recipes.com/create[/url] instead.
I'd probably make 10ml instead of 5ml just to make it easier to weigh out etc.
[IMG]http://i.imgur.com/J51SeKZ.png
Been vaping the RX200 all day. I'm really rather impressed.
I've got the black one and it actually feels better in the hand than the DNA200 version due to the rough texture. It looks the business with a black tank on there too. Been running the new black Aromamizer with a simple clapton Kanthal build in it.
TC in SS mode is kinda poo. It works but cuts the power so dramatically that you get a blast of vape and then nothing while it sorts itself out. Not ideal. Seems fine with titanium though.
All in all, it's a fantastic mod for the money and the more I use it and my little VTC Mini, the more I wonder why I bother with expensive SX350J and DNA200 mods when you can get a really, really good vape for a tiny fraction of the cost.
Talking of which, having gone from Kanthal to NI200 then titanium and finally stainless steel in TC mode I'm actually moving back to simple kanthal builds more and more. No messing about and I know the same build at 50W will be the same no matter what mod I stick it on.
Once I start pulling out my mechs I'll have come full circle.
I thought it was a 'cheapo Chinese mod'
