Just been down to
MCT Suspension in Stowmarket to have my rear shock rebuilt and forks sorted so bit of a review/recommendation.
As an Öhlins dealer/service centre they could have just sold me the TTX GP shock and FGRT forks I enquired about for 3k odd and be done with me. Instead they had already recognised the issue with the stock shock and knew exactly how to fix it.
Something to do with the shims and the way they stop oil flowing means the shock is just trying to compress the oil at the top of the stroke and no matter what settings you put into it you can't get it to work correctly. Then the action of no real suspension in the rear in turn upsets the front. It took them about an hour to modify and rebuild it.
Forks were then a simple fix and with the static and rider sags correctly set, then 10 minutes of bouncing the bike adjusting the dampening Darren took it out for a ride, he came back and let me loose on it, wow what a difference, it now wants to dip into corners like a little 600 and holds a line so well you can get on the throttle with confidence, the suspension is actually working when I go over bumps and not trying to throw me off the bike!
So instead of spending three grand just on parts I spent a little under 300 quid and if feels like I have a new bike under me.
I went and put another 100 miles on it on the way home, just couldn't stop riding
I now have a settings sheet from them and included service is free updates, so if I do a track day and call them up with some tyre wear info they will suggest settings or pop back in and get it adjusted during the summer free of charge. Customer for life now that is for sure!
If anyone wants some work done I suggest you contact them, even a basic setup would be money well spent or a full service if your shocks haven't been done in the last 10-20k miles but be quick as during Spring/Summer/Autumn you are looking at 3-4 month waiting list! They are already now booking for the new year.
Very highly recommended.
