Took a chunk out of my 3 week old carbon fibre exhaust, caught it on the edge of a wheelbarrow in the garden![]()
Devastating
is it repairable?Took a chunk out of my 3 week old carbon fibre exhaust, caught it on the edge of a wheelbarrow in the garden![]()
is it repairable?
Devastatingis it repairable?
Yeah I need to get some waterproofing wash or spray for mine as well. Getting a little leaky, but then I'm not sure if that's a gap somewhere or actual leaking waterproof removable bit.I never washed my textile yet, it is 6 months old, but I use only 3 times per week and only for a 2 miles journey but I'm feeling the need to wash
For longer journeys I use my leather kit.
Probably I need to order some special detergent and a waterproofing spray.
I'd love to pick something up for around £6-8k but there's nothing out there that interests me, and normal naked bikes are just too compromised for carrying 70+ litres of soft luggage. yeah it'll fir on the back but comfort will be affected, nothing worse than having a bag mounted right up against your back so much so that you can't sit properly upright or move about a bit.
That was my thought. Really I could have got away with just washing the liners as the thermal one touches just my arms, the actual jacket doesn't.Haha, my textile kit gets washed when it rains! But then I never wear it next to the skin, I always wear jeans and at least a t-shirt and thicker top underneath..
All you shorties![]()
price not quite so bad.
That'll be mounted to my SV, the 20l wasn't too bad for a few days but meant I'd normally have to stick my R35 on my back as well for one or 2 bits so the US30 should do for most of my stuff.
I picked up the tank adaptor as well so if needs be I'll have 70l at the back, 10l on the tank and then 35l on my back. Should pretty much be able to move out using just the bike if I want![]()
You can also strap a 3rd bag to the top, so you could have the US70 combo and a US10/20 on top of the US30![]()
