X5670 (4.2GHz - no turbo) and 6700K (4.0GHz - turbo default, so no turbo with all cores active)
X5670 fps 6700K fps
x264 107.83 108.49
x265 62.47 77.35
My P6TD is rebooting now too, I can make it reboot with a quicksave from fallout 4, not tested GPU/PSU yet.
So, I've finally got a Skylake build working (second try with motherboard) and I've run some short x264 and x265 encodes (only DVD resolution and 25 minute episode though!).
Just some quick results as I only got it working last night.
Code:X5670 (4.2GHz - no turbo) and 6700K (4.0GHz - turbo default, so no turbo with all cores active) X5670 fps 6700K fps x264 107.83 108.49 x265 62.47 77.35
Not a varied or exhaustive test, but it gives an indication of improvements over the generations (IPC and features such as AVX, FMA)
It also means I can retire my 5670 to being a encoding box for many DVDs without thinking it could be done much quicker on the new machine![]()
My now 7 years old Gigabyte X58 UD5 motherboard is finally starting to die. Random restarts no pattern to it. Happens in IE browsing, Gaming or just sitting on Memtest+ screen. It can be stable for 24 hours or slighly longer then suddenly it restarts without warning...
No overclock ever just the std Intel Turbo boost 3.46Ghz (from 3.33Ghz).Do you have an overclock on yours? tried default clocks on everything? I had a similar issue and it stopped rebooting when I went to default settings. I had a stable overclock for like 8 years ha now im stuck on 2.8ghz
I benched my 6700k at 4.6 against my x5650 at 4.0 and its 60% faster per thread. If you just play fps games you'll probably be fine but the reality is that you are going to be bottlenecked a bit imo. I noticed a significant improvement when playing supreme comannder but that does use a significant amount of cpu.
It'd be ~40% faster at the same clock speed.Not surprised, I benched mine for single threaded performance and it wasn't great compared to newer chips. Although the fact the 6700k is clocked 600mhz higher doesn't make the test a good clock for clock comparison.
