If you don't like how the os is laid out in the honor 7 you can just install nova and use a different launcher. It seems as though whether you use a xiaomi, letv or huawei, you'll get a standard layout which works in a similar fashion to ios. It doesn't bother me too much to be honest. I use nova launcher occasionally. The huawei is a tiny bit more expensive than the letv. If I get a problem though I can just send the honor back to Amazon for a replacement. Not sure how easy an letv is to get fixed. They both got upsides and downsides I guess
