Ok so a few hours in with the Wotofo Serpent.
I ordered mine from Noble Vaping:
https://noblevaping.co.uk/wotofo/serpent-rta-by-wotofo
Not out of preference, they just so happened to be the only place I could find with stock!
Anyhow, the bar is pretty high on £20-30 RTA's at the moment, Aromamizers, Crius to name a few, how does this stack up?
Build quality is very very good, no machine oil, smooth threading, juice control that works, everything works nicely!
Putting a coil in it was more tricky then I'd first anticipated, the post holes are offset to line up with the wicking holes, this means you can't just drop a coil in as you normally do, you have to really work with the second lead to get it in - but with a little practice I'd imagine it will become easier in time. A little tip, if using a coiling jig with this (I used a coil master v2) and you hold the winding end cap with you're right hand, wrap under not over, otherwise your leads will end up the wrong way around!!
Wicking, a doddle tbh, mahoosive juice well, wet it, poke it in a bit (giggedy) and you're done, doesn't get much simpler.
I opted for 5 wraps of UD's 26/32 clapton wire over a 2.5mm post, reads out right around 0.69/0.7 ohms.
Wrap it over first and this is what you have to contend with...
Airflow isn't as 'huge' as reviewers were making out, perhaps it was due to them using wotofo's so called 'competition coils' - which I tested btw, garbage, get silly hot over 30w and wicking can't keep up as their only wrapped over 2mm. Airflow is actually spot on for me wide open on this clapton build, for smaller builds you'll want to dial down the wattage and close up the airflow a little to suit
Flavor is very very very good, have it at 40w, sat on the RX200, using a familiar liquid, its up there with the best I've tested, clouds are dense too.
Unless it decides to do something stupid like empty a tank of juice over everything in the middle of the night this RTA is a solid 8.5/10
The cons, some, nothing drastic. The 510 is adjustable...only that once its wound all the way in its still a touch to tall to sit flush on the RX200. As well documented the glass tank section doesn't dissemble for cleaning/replacement. The airflow control ring doesn't lock in any position, it just moves freely all the way around, its not loose, doesn't move on its own, not a major issue but its still one.
I'm also going to mention the deck posts, they gain next to nothing having it offset, all it does is make it a pain in the arse to stick a coil in
