Try solution I just posted working 100% fine here and on the system in Technical which had exactly this issue. Main thing is to get Turbo settings correct. Otherwise freeze on Windows Logo screen.
Mate who uses windows update. No offence but who does!! I have never once and its not effected me.
You want instability and slow perf use windows update.
But for me I update nothing and am sure I missed out on nothing!!
I expect the amount of hardware changes his systems (probably) go through is mind boggling! He doesn't need a system to run all day every day typing in Excel, clicking Send/Receive in Outlook and refreshing Chrome...
Pretty sure they sometimes doOr do you think they're just breaking stuff randomly for a laugh?
However I do of course still think it's still far too easy for any windows install to get mucked up over time. Just through normal usage. Not specifically performance-wise, but in many other ways. All quite unpleasant / impossible to rectify aside from the commonly accepted fresh install proceedure.
Not quite sure when a fresh install every few months wasn't the best way to do things anyway?
People, you need to bear in mind that 8 Pack is always after performance and overclock stability, his day-to-day is ragging systems to their peak!I expect the amount of hardware changes his systems (probably) go through is mind boggling! He doesn't need a system to run all day every day typing in Excel, clicking Send/Receive in Outlook and refreshing Chrome...
This is exactly my point. The OS becomes very inefficient with time. Especially when adding updates to this.
Not quite sure when a fresh install every few months wasn't the best way to do things anyway? Peak performance - even on 7! Although I've been quite lax recently due to all of the big game updates and my slow connection... Good shout with WSUS - I use it at work when nuking and paving old PC's!![]()
Still no joy, same as before.
What is the issue. This is working 100% for me on many systems.
Try as u did last night i34500. Go into windows.
Then up blk to 125 and adjust mem frequency so mem speed is less than 2666. Reboot into windows and slowly work up. Making sure each time mem frequency is less than 2666.
Hi MillermillaStill no joy, same as before.
Installed BIOS 050
Loaded i54400 profile and saved
Re-booted but Win 10 will not boot
Test with lower memory multi. SO drop the memory lower and try OC CPU.
Sure. Don't worry I will fix it for ya myself. Could be one of many things so I will test it out. We sold many of these bunbles and this is the only one that has not been an easy fix. 98% have just worked.
Request an RMA in the customer service section with Bailey. I will speak with him tomorrow and make sure all the components come to me for testing. I will then test, replace and return. Include your ssd also if u could please.
Sorry for this issue really its very strange but just like with all components some do fail.
