- 30 Oct 2002
- Inverness (UK)
... unless you're happy with each button on a pad having multiple uses.
I use 2 x modifier keys...
Quickly get used to it
oh delivery routes and undermining help rank? Ok that's not too bad though?
I can't see any other way of ranking up quickly other than getting a Interdicter and getting a massive bounty on my head
Servers were misbehaving, fixed now according to FD support on twitter.Anyone else having issues with playing tonight?
All I get is that.
FAS you say... how come?
Had 6M credits worth of slaves running from Robigo during all the disconnections. Took way longer to jump the 380 light years than it should have and then to cap it all I got scanned whilst sneaking into my first drop off. Epic Fail.
I always tend to drop off at the smaller stations before I go for the letterbox types, tend to get scanned less, if that helps...
