I just set mine up using Nvidia control panel. Create a custom resolution to suit the aspect ratio and the resolution is then available to use in game.
Thanks that worked, does look good, and after a bit I never noticed the black bars![]()
What res are you running there David? Looks much better than what I have been using!
And how have you adjusted the FoV in ATS?
I have purchased a different display port cable, and so far (touch wood) I have not had any of these issues reoccurring![]()
Does any one want to swap 3 1080p 24inch+ monitors for my bdm4065uc? i'm bored of it, still in guarantee purchased 30sep 2015
Glad it worked ok.
I just set up a custom res using 3840x1620 no other changes were made.
No need to make any in-game adjustment in ATS. What you see on my screen is the default once you set to ultrawide resolution.
When I try this is how my screen looks at the same resolution. Your FOV seems so much wider than mine - I have my seat all the way back too.
