Dunno, all about that CS i guess. Bird looked like a porn star who dealt with me. Only reason i hung around and agreed to the VHC to be honest.
Amazing.
I was also doing some virtual shopping last night, as you do and I reckoned I could get a decent E39, E60 and F10 M5 for 70K all in with some aggressive shopping. I've got nowhere to put them but I think that would make an interesting collection as they all do what they do differently, though I suspect Fox might have a heart attack at the incoming thread.
Things I like:
It beeps when I leave the car and have left it in drive.
[TW]Fox;29205170 said:Whereas your F11 just puts it in drive for you and leaves you alone![]()
Think my front discs are warped, quite bad vibrations under braking
Just had new pads all around too, annoyed. Goes into BMW to be checked over but I suspect will need to swap discs again. Also as we are keeping it as our run around/tow car I'm going to get the suspension made new as with close to 90K miles it's feeling a little tired.
What does pro-nav give over Business Nav please?
[TW]Fox;29205202 said:It is a completely different vehicle on a completely different platform - hence the old style gearshifter as the ZF 8 Speed in your F11 won't fit into an FWD car, etc.
Luxury doesn't add Surround View as standard on anything - order a 550i Luxury and there is no surround view so I'm not sure why you'd expect an option as exotic as that to be present on an FWD MPV? The main addition of Luxury spec is generally Pro navigation.
[TW]Fox;29205357 said:No, surround view is very much not standard on the F10. Its a comparatively rare option.
[TW]Fox;29205411 said:Yea, its really really excellent but almost never specced.
Because who cares about useful tech as long as the car has big wheels and tints![]()
I've started getting an rubbing / abrasive noise from my driver side rear wheel. It started quite suddenly with a very small clunk. It is intermittent (for instance I didn't hear it at all on my 3 mile drive this morning). It made a similar noise last year which turned out to the be the handbrake shoe / handbrake drum which was falling apart and had rusted bits spinning around in it. It was replaced. Could the same part have gone in about 1 year / 8,000 miles? Its an 346 330ci
Odd, the suspension on the E60 (157k) has no obvious signs of wear other than a replaced front arb and tie rods. Perhaps that's all you really require?
