So, been doing some research on what braided brake lines to get, found some posts on  other forums about people saying Cobra Performance are licensed under Hel but nothing confirmed or concrete about it.
So yesterday i emailed CP and to confirm, their response was:
They only sell via ebay now:
http://www.ebay.co.uk/sch/cp-racetec/m.html?_nkw=&_armrs=1&_from=&_ipg=25&_trksid=p3692
Just thought i would pass this info on, for my Hornet a full set of 2x front race setup and 1x rear £59.99 delivered with lifetime warranty, they will also send a few P clips if asked for free, cant go wrong at all.
on another note, anyone used Red Rubber Grease? i am rebuilding my calipers, waiting for the rebuild kit and Red Grease to arrive.
having a look here shows how to use it, does it seem a bit extreme?
http://www.redrubbergrease.com/tips-how-to-brake-caliper-failure-repair-with-rebuild-kit.html
how much is actually needed? smear the seals inside and out, fit seals, smear piston with Red Grease and pop it in, then lube the inside of the rubber boots and slider pins.
