Bikers What Cam Do You Use?
Caporegime
OP
11 Jul 2009
BenefitStreetBirmingham
I still haven't got round to mounting it yet,I need to order some sugru
You can tell it's cheap though,and the battery life isn't that great,some folks put an sj4000 battery in which lasts longer
If I was buying again I'd buy the xiaomi yi,soon as I get it mounted I'll put up some footage
IC3
IC3
3 Dec 2011
Xiaomi Yi with 35mbps firmware and couple scripts is a 'gopro killer'. :D
If anyone wants some RAW footage, I can post it on here. :)
IC3
IC3
3 Dec 2011
can you provide more info and links please mate?
http://nutseynuts.blogspot.co.uk/2015/06/xiaomi-yi-action-cam-custom-scripts.html
35mbps firmware
22 - 23 - 23A - 23S = https://drive.google.com/file/d/0BxO_QexYT9EAT2xFWmZQcUtWUVU/view?usp=sharing
22L - 23L = https://drive.google.com/file/d/0BxO_QexYT9EAcVdRZy05OWt4alk/view?usp=sharing
RAW Footage with 35mbps firmware and couple scripts, lens rectification OFF, Auto lowlight - OFF and lightning set to: Matrix recorded in 30fps.
https://mega.nz/#!jwQziIQI!ywKvzvQoWlIgvdi5DkobC2ZM1k_VDKkujJ8Wi-PH9rA
12 Feb 2004
Manchester
thanks for the info mate, looks good.
24 Mar 2011
Kent
I use mine every day for commuting and it's never crashed/stopped recording etc. or corrupted files.
It would be perfect as a 2nd camera if you had something else to record audio with, plus it can record whilst being charged/powered (even without a battery in) so perfect for mounting on the bike with power and just set to record. I get roughly about 7 hours of 1080p 60fps high setting video on a 64gb SD card.
24 Mar 2011
Kent
On the Yi it splits the video into 1.85gb files which are normally 11 minutes 30 long.
I currently have 230 minutes on my 64gb (59.5gb) card and that's used 37gb, so 22.5gb left.
I think that's roughly 350 minutes for a 64gb card, just under 6 hours. That's on the 'high' quality setting and 60fps.
