Always turn off wifi and bluetooth scanning, massive battery drain on any android phone. Keep location history if using Google Now like I am.
last 3 hours with bluetooth on - not in use.
battery used? 0%
battery used? 0%![]()
Got mine, unfortunately GiffGaff don't allow sim swaps after 21:30 , so will have to wait until tomorrow. Does anyone know a simple way to copy across viber and whatsapp across from another Android phone ?
https://www.brodit.co.uk/brodit/holders/Samsung/Galaxy S7.htm
Brodit S7 clip if anyone is remotely interested.
If you phone up Brodit they will put you on the waiting list for the Edge clip but it's likely to be mid to end of April.
I've upgraded from the Z3 to the S7 Edge - first thoughts:
So yes for me it has been a really worthwhile upgrade over the Z3 - no easy feat as I had the Z3 from launch and it was a fantastic phone. Also, I got a decent price for the Z3 so cost to change was very reasonable.
- Screen is fantastic - really is as good as the reviews suggest. Feels no bigger than the Z3 in the hand which considering the increased screen size is great.
- Battery - early days but incredibly it seems at least on a par with my Z3 if not better. Very impressed as this was a big concern.
- Sound - loud and clear - always an issue with my Z3 at least on calls.
- Speed - seems a fair bit quicker overall. Although the Z3 was no slouch.
- Camera - different league to the Z3 in every way. Super fast to start, focus and shoot with fantastic results. Love it.
- Fingerprint reader - I have a work iPhone so missed this on the Z3. Works very well on the S7.
- Edge screen - bit of a gimmick to me so far but would imagine this will improve as more become available.
- Have also got the wireless charger which works incredibly well and conveniently on fast charge.
- Form factor - a lot more comfortable to hold than the Z3.
Do Amazon work 24/7? Still not had the phone dispatched. Spoken to 3 advisors, who have all given different answers. Last one said that it was because payment hadn't completed. Ended the chat and can now see that funds have been requested and that it's preparing for dispatch. So, no idea if it's coming later today or not lol.
what's the fault out of interest ?
While not a "right now" thing, BT scanning is required for BT beacons to work. There's only a few really good implementations of this tech out there right now (by a mile the best to me is the Levi Stadium of the 49ers did this absolutely nuts integration into their app: http://techcrunch.com/2014/11/04/how-the-49ers-are-using-beacons-to-help-you-find-hot-dogs-and-beer/ )What do we reckon? Location history with wi fi and Bluetooth scanning on or off?
When opening the camera app, it hangs and pops up "warning - camera failed" on the screen. Tried all advice I could find, including factory resets. Each reset, it would work again until a reboot, then same failed message. Couldn't see anyone else with the same fault on here or XDA, so just unlucky I guess.
This has literally just started to happen with mine.
You can try force closing then clearing the data for the camera app and see if it helps, or just a simple reboot. Most people say that has helped on previous galaxy phones. Didn't work for me. Only thing that did was the full factory reset and each time, problem recurred within 30 mins. I didn't have anything fancy installed on it either, just the usual social networking and news apps I always use. Only good thing is the novelty of having a new phone has worn off slightly now and I am happy enough to wait until Tuesday to receive the replacement. I have the regular S7 by the way...
Can someone please try exporting an app to the SD card? I just tried and it just hangs on the Export screen and then doesn't seem to transfer. I press back and then it is still reported as being on the internal storage...![]()
