Running Ubuntu on my dual xeon setup, but thought I'd join the party and share my benchmark on geek bench
http://browser.primatelabs.com/geekbench3/5613161
Do me a favour dudes - can folk check that they can wake their system from sleep ok? Ever since I have fitted the Xeon 5650, I can put the PC to sleep but when I tap the space bar to wake it up, the fans spin up and it appears to come on but I get nothing on the display and the monitor remains in standby mode? Worked fine with the i7 920.![]()
Change Command Rate to 2T and push the bus speed again.Hey all, could anyone let me know if I am gimping my RAM speed too much for my x5650 overclock (just under 4Ghz with 1.325 CPU volts). Had to set SPD multiplier to 6 to get it stable. Max temps on prime = 63 deg. C with Noctua nh-D14, but think its RAM speed that is limiting me. RAM volts = 1.66
Here's parts from CPU-Z dump...
Core Speed 3959.5 MHz
Multiplier x Bus Speed 22.0 x 180.0 MHz
Memory Size 6 GBytes
Channels Triple
Memory Frequency 539.9 MHz (2:6)
CAS# latency (CL) 8.0
RAS# to CAS# delay (tRCD) 8
RAS# Precharge (tRP) 8
Cycle Time (tRAS) 24
Row Refresh Cycle Time (tRFC) 60
Command Rate (CR) 1T
Uncore Frequency 3059.7 MHz
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Corsair (7F7F9E00000000000000)
Size 2048 MBytes
Max bandwidth PC3-10700H (667 MHz)
Part number CM3X2G1600C8
That's a lot of coresWhat mobo?
Start here and work backwards in terms of voltage as mine i know i have to push higher / harder than most:Hey, thanks for that. I set mem Command Rate to 2 and upped BCLK to give 4.11Ghz. I got a Windows 10 'System Service Exception' on boot.
Any voltage tweak to cope that I may not have thought of?
Vcore is 1.325, QPI = 1.315
I'll have a fiddle here and there, as I'd really like 4.2Ghz seeing as my i7-920 was good for 4Ghz
an EVGA SR2, which appears to be as rare as unicorns.
https://forums.overclockers.co.uk/showpost.php?p=29241024&postcount=2079
Still need to get it its own RAM as i've stolen the 8GB that's suppose to be in my 3770k system, but i'm happy to use this for a while![]()
I have a spare 6gb triple channel kit going on the member market this weekend if you still need one then.![]()
