- 11 Jan 2007
- *̡̡ı ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡
I'm still awaiting my Gear VR. Hopefully tomorrow. I have Mad Max 3d to watch.
Can VR games and things from the Google app store be used with the gear VR? Things made for cardboard etc?
Download the Jack the Ripper short, it's awesome.
I watched a 1080p episode of Gotham whilst sat in the virtual cinema, that looked pretty good tbh. It definitely shows potential but does also highlight you need a minimum of a 4k screen for VR. Even on the S7's 2k screen you can see the pixels quite easily.
Yeah but you have to temporarily disable the Gear VR service first
Yes but you need to disable the Oculus Home service first with package disabler pro (£1.50 on the play store) or pop your phone into the GVR under the micro usb connection (careful not to damage it) to prevent Oculus Home launching.
A few days ago i saw one place selling the S7 edge screen for £259 and £37 for the rear cover or back part.The screen is part of the touch screen apparently which costs more to replace than the phone is worth.
Can anyone please confirm how to check which camera sensor is fitted?
Just watched some 1080p and 720p 3D (which for what its worth are the same due to the screen)
Gotta say, its actually pretty good. Yes, the pixels are there, but it doesnt take too long to forget about them. Very immersive, and sitting where I normally sit to watch my 55" tv, comparatively it is absolutely huge. Its around 7 foot away from my TV, and if I lift the unit off my head to see the TV, the image inside the unit is at least twice the size. And this can be increased further, but perhaps it increases the amount of pixels you see.
Its very nice indeed for a £80 (or free) device : )
It is in post 2555
Use this code in dialer *#34971539#, then press first button.
In Cam FW Ver string you will see 11 digits and letters.
The 5th letter tells you what sensor you have.
L = Samsung
S = Sony
Was someone having problems with the Samsung browser and logging into your PayPal account using your fingerprint ? I've got a solution and I've just tried it and it worked for me basically after registering your fingerprint to your login details.. you need to go to settings > advanced > manage website data. You need to clear it. And that did the trick for me I can log into my PayPal using just my fingerprint.
Themes people recommend
