- 18 Oct 2012
Another vcmt update; all i can taste is butterscotch.
That is all
That is all
Quick note to say thanks for RX200\DNA200 advice. Went with DNA200 & Samsung 30q's. Have spent far too long changing screens and looking at stats. Might start to dabble in some temp control soon. I've seen that Ni\Ti are supposed to be a bit tricky to work with. Is SS worth looking at?
Did you get the Reuleux DNA200... good choice.
I would avoid NI200, TI and SS are far easier to work with and SS i feel its the best all round, the fact you can dry burn it or run it in power mode as well as in TC mode, makes it an all rounder, i use 25awg 317L for single wire coils and i have two reels of Claptoned 316L too, far easier to work with compared to NI200 and no funny flavour bedding in like you can get with TI.
I concur. SS is so versatile it's the only wire I use now. The only trick is that you need to get your power set right when in TC mode or it will heat up too fast then struggle to maintain temperature. With TI and NI you can just whack it up to max and let the temp sort itself out.
SS is absolutely great though. TC or Power on the same build no problem. Spaced, contact, clapton or twisted no problem too.
Along with the vcmt, this proves the 510 is an inadequate standard for modern vaping kit.
Also why, what mod could even power that?
That RDA is ridiculous... theres no mod that would Not look stupid on... on another FT note, i see they now have the COV Mini Volt... £23
If I had money to just fling around I'd probably get one, plonk it on a hammer of god, just for a bit of fun![]()
Novavapes Sour Fruit Crush and Rainbow Dust are delicious, but damn 70% VG is gloopy as hell!
No leaks (yet) and the nozzle on the novavape bottles are tricky to fill the Crown with (other juices I have are very thin nozzles), and flavour is definitely muted a bit compared to the high PG Hangsen stuff. Might try 60/40 in the future for a bit more flavour.
)This just proves that a handful of vapers are completely ****ing stupid
Products like that are totally unnecessary, nothing wrong with the 510 connector that has been become standard
They also have the artery nugget too for £19
Think I'm going to move the VCMT on, 30mm is a bit much for me, I expect the 25mm to be much better, the 30mm is feeling more like a novelty.
From a purely engineering perspective its not well sized for even a 25mm tank, as well as the inconvenience of tanks not being able to stand well on their own.
Provari are onto something with their p3, its just itll need more adoption methinks
Already? That wasnt that long lol.
Although i do confess im thinking building a little less next time, its current config is more powerful than i can afford to keep
