I do really like those CBR6 F's & that's one of the better colours as well, No vid clip of the end can Blasting is Major Fail though![]()
I'll sort something out on the weekend. Problem is video audio never does them justice!
Wheel bearings will be the hardest bit/most expensive, I'd do the fork seals myself if you have the kit.
Failed it's MOT, leaking fork seal and wheel bearings.![]()
If you have stands and they're aren't seized in the wheel, bearings are dead easy to replace?
How old is your bike/how many miles?
Definitely easier and quicker than changing fork seals.
Does it not come out using the inner leg as a slide hammer, the bushes inside pushing it out?
