I expect the below on release date, reference available at the higher price and preorders available for custom designs at varied prices depending on brand. Similar to the 980Ti release.
I like how you blurred pornhub out
A 980 was not good enough for 1440p/60fps, no. Not because of bandwidth, but again, because of horsepower. A 980Ti is only *just* good enough for 1440p/60fps and that still involves lowering settings in plenty of games. So of course anything less wont be.
And I didn't say anything about better memory bandwidth not being good for higher resolutions. But I think it's important to note that these bandwidth bottlenecks only *really* start to pop up when you get into really high resolutions like 4k. I think it's very easy to forget that 1440p is only 1.7x as many pixels as 1080p, while 2160p is a full 4.0x!!!! 4k has become such a household name around here, but I dont think people are quite appreciating the sort of leap it is. 1440p->2160p is a greater leap in resolution than we've ever, ever seen by far. And from 1080p, it's the freakin Grand Canyon.
What holds GP204 back at 1440p is definitely not memory bandwidth. I'm not saying it plays no part at all, but it's not going to be a notable bottleneck.
i think its diff for 980ti vs 1080
980ti cooler can be copy/pasted from 980.
1080 most likely can not. (different hole placement gpu size etc)
i think it will take longer![]()
1080 is going to be faster for more reasons than just GDDR5X.The 980ti would not be as fast with a 256bit bus though, when I said 1440p or higher I meant 2560x1400 or 3440x1440, 4k is a silly resolution for any card including the 1080 and probably 1080Ti as well. A very obvious way of measuring this will be the 1080 vs 1070 where one has GDDR5 and one has GDDR5x, other than that they will be similar. But I don't know why they are putting all this effort into GDDR5x and HBM if memory is not something that needs to be improved, or why bother giving the 980ti a 384bit memory bus if it is not necessary? I think it does make a difference, because if the 1080 was released as a GDDR5 card with 256bit bus, and not a GDDR5x like it is... it would not be as fast and I would not be very interested in it.
Probably controversial opinion but I've always thought the only reason companies made third party coolers was because they were cheaper and they could save money.
So now we're believing random obscure Chinese blogs unquestioned?
Every NV launch same mass-delusion.
And again, I'm not saying better memory bandwidth isn't useful. Just that at 1080p and 1440p, 256-bit bus shouldn't become a significant bottleneck(a big issue, in other words).
I think a more useful comparison will be looking at the 1070 vs 980Ti and seeing how they do at different resolutions.
I'm sure this has already been asked before guys, but is it worth upgrading my 980ti SLI set up to 1080 SLI or waiting for the 1080ti's that will inevitably be here within the next year?
Thanks.
Is a gtx1080 too much overkill for 1080p 144hz
I was thinking the same thing, while the 1080 looks to be nice upgrade over a single 980Ti I am personally going to wait for the 1080Ti as I would consider this a direct replacement and should be a very nice performance increase over the 980Ti and probably even the 1080 looking at the 980 to 980Ti benchmarks.
Nvidia has done the 780Ti and 980Ti so I would shocked if they didn't do a 1080Ti.
If Nvidia does the 1080Ti this time around it's going to be an amazing card and should be worth the extra few months wait.
I like how you blurred pornhub out![]()
