Please tell me the process and products for sealing the drive? I want to do mine.
Go on adseal.info website and buy driveway super sealer I got 25 litres for my 75 sqm drive used basically all of it , phone them up as they do big discounts. They are in Bolton I just go on shop for driveway stuff
Day 1 - jet wash drive or use proper patio attachment. Be careful only to remove 10-20mm of your old sand.
Let it dry out and do not park car on it
Day 2 - re sand with dry kiln sand, just poor on and brush in to all the gaps. Use a leaf blower and feather the throttle to remove any access sand and dirt on the drive. Obviously don't use full power or you'll just blow the new sand straight out the joints.
Apply first coat with roller. Look on YouTube for the method basically be generous but roller in properly.
Wait an hour and then do second coat. Lash it on in the opposite direction
Leave 24 hours before parking car
